8 inch rear
Old Jul 9, 2006 | 07:13 AM
thomc's Avatar
thomc
8 inch rear
I just got a rearend from a 67 Fairlane to use under my 56 F100. It is an 8 inch with 2.79 gears , which is what I wanted . Im wondering if I can update it with brakes off a later model, with wider shoes & drums. It now has 10 x 1.75 brakes. Can I put on 10 x 2 brakes without changing the axles ? I do not want discs.Thanks .
Old Jul 9, 2006 | 07:26 AM
GreatNorthWoods's Avatar
GreatNorthWoods
Check with your parts house on brakes for a station wagon near the same model year. They often had larger brakes due to the extra weight. You should be able to bolt on the wagon brakes and drums without changing the axles. I seem to remember an article about doing this in a magazine years ago...
Vern
