Fail Safe Mode?
Old Jul 8, 2006 | 06:49 PM
MUD BUGGY's Avatar
MUD BUGGY
Fail Safe Mode?
I got a fail safe code on my dash and checked it with my EDGE its a 04 F150 5.4 and it was P2106 throttle actuator control system-forced limited power what does this mean. i reset it and it went away!
Old Jul 9, 2006 | 10:23 AM
DASTUD's Avatar
DASTUD
i go the same thing when i tune my truck to level three. It must set something off in the computer when you first tune it from stock. All i do is turn the truck off, restart it and clear the code. I have had no other problems since. You will probably have this problem everytime you return to stock, update the evo and reprogram. I would not be alarmed, but i would like to know if any others have had this problem. mine is an 06 5.4
Old Jul 9, 2006 | 04:27 PM
JHag04FX4's Avatar
JHag04FX4
It is a system ford has that is called "limp-home" mode. Sometimes mine does it when i drive around in town on level 3. Reset it to stock and then back to Level 3 and you should be ok. Edge should try and make a program that overruns it, IMO. But i was told if you bust a radiator and cut a hose it allows you to get somewhere safe by fire the cyclinders in a sesquential order instead of all at the same time.
Old Jul 10, 2006 | 05:00 PM
powerman88's Avatar
powerman88
I did it well.
pony
Aug 12, 2015 04:42 PM
m@m
2004 - 2008 F150
Aug 21, 2011 04:31 PM
weldude
Aug 4, 2011 04:08 PM
