Timing chain - what'd i do wrong?
Old Jul 8, 2006 | 11:59 AM
poboy's Avatar
poboy
Question Timing chain - what'd i do wrong?
1964 F100 with a not original 223 6 cylinder. replaced timing chain set, made sure dots lined up, but the rotor is pointing at #4 instead of # 1 when at TDC. shouldn't it be pointing at #1? what am i missing? also need advice on valve adjustment procudure...any help greatly appreciated!
Old Jul 8, 2006 | 12:22 PM
RangerPilot's Avatar
RangerPilot
Something is reversed 180 degrees if it's anything like our engines in the Rangers.
RP
Zach
Old Jul 9, 2006 | 02:18 AM
customcab66's Avatar
customcab66
Not sure if they are the same as the old 292 but the dots line up bottom to bottom both dots point to the bottom of the motor.
Old Jul 9, 2006 | 04:53 AM
captchas's Avatar
captchas
Guest
one need to be very carefull with some older motors they are some times dot to bottom and top 6 and 12 oclock or as said above 6 and 12 oclock. some you even had to count the links between the dots valve adjustment i don't remember off hand but best way is to tap the starter till both are free and do 1 cyl. at a time. again thats a motor i didn't work on much in my days so i'm a bit weak on it. best to get your hands on a shop manual and copy the pages
Old Jul 9, 2006 | 11:11 AM
airharley's Avatar
airharley
Pull the #1 spark plug and valve cover. Rotate the engine until the cylinder is at top dead center. Once it is then rotate the cam shaft until the intake is past closed. The theory is that the cam and piston will be at the firing point. This will give you an idea of where the timing marks are supposed to be in a pinch unless some one has the actual asnwer.
Old Jul 10, 2006 | 08:12 AM
R Pope's Avatar
R Pope
Y-blocks and 223's are timed with marks on the sprockets and the chain. On your 6, get both marks on the upper, drive side, and line a mark on the chain with the marked tooth on each sprocket. Some aftermarket chains don't seem to have marks. In that case, there must be 12 pins between the marks.
Just one of Henry's better ideas!
BTW, the last 223's used a gear drive and reverse rotation camshaft.
Old Jul 10, 2006 | 08:23 AM
R Pope's Avatar
R Pope
Oops! forgot to add, valve clearance is .015 hot, intake and exhaust. Best way to set 'em is---get one cylinder at TDC, split overlap (Exhaust closing, intake opening) and set the valves on the one 180 deg. away in the firing order (153624). EG, #1 split O'lap,set #6, #5 split, set #2, etc. Once you have one done, turn the crank 1/3 turn for the next one.
Old Jul 10, 2006 | 04:37 PM
hiball3985's Avatar
hiball3985
this wrong, lash should be .019, intake and exhuast
Old Jul 11, 2006 | 06:52 AM
R Pope's Avatar
R Pope
My books say .019 for Y-blocks, .015 for sixes.
Old Jul 11, 2006 | 07:08 AM
hiball3985's Avatar
hiball3985
I don't know what book that is but its wrong, sixs have been .019 since 1956-1964
Old Jul 11, 2006 | 09:15 AM
poboy's Avatar
poboy
forgive my being dense, not sure i understand the method you describe. what is the upper, drive side? the replacement chain has no marks, so i need to know what pins you are referring to....chain links, maybe? i love these forums, but sometimes i have trouble with textual explanations versus verbal. your help is really appreciated!
Old Jul 11, 2006 | 10:57 AM
stockcar nut's Avatar
stockcar nut
lay the sprockets on the workbench with both timing marks pointing the same direction and place the chain around them, move one sprocket around untill you can count 12 pins BETWEEN the two timing marks and then mark the chain with some paint or something that will stay on it long enough to install it. where ever the distributor is pointing once the timing is done is where number one will wire from.
Old Jul 11, 2006 | 09:15 PM
R Pope's Avatar
R Pope
The marks must be on the right hand side of the sprockets. The key in the crank will be facing straight up, the key on the cam straight down. The twelve pins are the pins in the chain. Look closely at both sides of the chain, there are likely small dots on two of the plates on one side only.
Old Jul 11, 2006 | 09:35 PM
poboy's Avatar
poboy
thanks, guys, i got it now. i swear, i must have replaced 150 timing chains/belts in my life....just when you think you can get comfortable, you learn something new! cool! will follow up after trying again. thanks!!!!
Old Jul 12, 2006 | 06:45 PM
poboy's Avatar
poboy
I really appreciate all of the help on such a simple topic, folks. Just have one last question - I would prefer to adjust the valves while I have everything apart i.e. while they are cold. Anyone know the cold lash setting for the 223?
Also - what is the best way to post photos here? My '64 is definitely a "hooptie", but I still like to show her off!
