What does 4 Low mean!!!!!
Old Jul 8, 2006 | 06:22 AM
BlackFX4Screw's Avatar
BlackFX4Screw
Angry What does 4 Low mean!!!!!
About three weeks ago my wife was using my truck. She calls me and ask what does 4 low mean? The truck is hard to steer. I tell her how to get it out and everything is fine until.
After my truck sits over night I have a wine in the front end. After I go 10 or so miles it stops. If I put it in 4 high the wine goes away. Change back to 2 high the wines back.
Ant thoughts on what this could be?
Old Jul 8, 2006 | 09:47 AM
Fordtastic's Avatar
Fordtastic
From my experiance when you put the truck into 4wd move, the steering gets heavier, i guess from all the mechanicals running. Anyways Was your wife useing the 4wd mode on dry pavement? If so how fast and do you do the same?
Old Jul 8, 2006 | 09:50 AM
Fordtastic's Avatar
Fordtastic
By the way your truck may have come with an instructional VHS tape that explains your 4wd system. But I believe 4-low provides a higher gear ratio to make it easier to get out of tight spots, or if your hauling a heavy load in less than ideal conditions.
Old Jul 8, 2006 | 10:29 AM
WhëëlMå1's Avatar
WhëëlMå1
What kind of driving did she do in 4 low, and on what kind of surface? I will be honest, Im not very optomistic about what you are about to tell me.....
Old Jul 8, 2006 | 01:53 PM
awu_gigabyte's Avatar
awu_gigabyte
I have a feeling this thread is going to get sadning.
Old Jul 8, 2006 | 01:56 PM
BillC's Avatar
BillC
You know it will. Threads like these only go downhill fast!
Old Jul 8, 2006 | 05:16 PM
whitt6's Avatar
whitt6
Yet another PRIME example why you should never let your wife borrow your truck...
Old Jul 8, 2006 | 05:41 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Wifey. DO NOT! Repeat, DO NOT push any butons...Go from D to R to D and P on the gearshift lever. Use key to start truck!! Again, DO NOT PUSH ANY BUTTONS!!
Old Jul 8, 2006 | 06:56 PM
Sarge261's Avatar
Sarge261
This is exactly why my wife is not allowed to drive my truck.
Old Jul 8, 2006 | 07:34 PM
yellow98cobra's Avatar
yellow98cobra
If you are still under warrenty. I recomend playing Dumb and taking it to the dealer. Tell the service man that it just started making noise. Leave out the parts about your wife.
Old Jul 8, 2006 | 07:50 PM
BillC's Avatar
BillC
Funny, how it always starts out "my wife was driving MY truck and ....".
Old Jul 8, 2006 | 08:19 PM
slpin's Avatar
slpin
so she was driving around in 4 lo the whole time
uh oh!!!
Old Jul 8, 2006 | 09:31 PM
96f150's Avatar
96f150
Are you SURE she was in 4-lo? To put it in 4-lo, the vehicle has to at a stop, or barley moving. Certain conditions have to be met, otherwise it will just not go into 4-lo. Ask her if it actually lit up on the dash "4-lo", or did she just see the switch in 4-lo? Once again, I'm just assuming you have the electric shift t-case, not the manual lever on the floor.
Old Jul 9, 2006 | 12:55 AM
BlackFX4Screw
Its auto shift just turn the **** and there you go. She said it was like that whan she got in never said how far she went. Trust me somehow it will be easer for me to take the blame for this one somehow.
Anyway why whould it wine in 2H and not in 4 wheel drive?
Old Jul 9, 2006 | 01:02 AM
slpin's Avatar
slpin
you could put it to 4lo at high speeds
it just wouldnt engage till the next time she 'stops'
