Aerostar Ford Aerostar
Stops Blowing
Old Jul 7, 2006 | 06:51 PM
TrickStyle3L's Avatar
TrickStyle3L
Stops Blowing
Wow, this is odd.... My A/C blows cold, both front and rear. Today I took it on the highway for a little drive, it was doing great ! So I press the gas alittle more then next thing you know the front vents just kick off, and rears are still blowing cold?!? I let go of the throttle alittle, front vents start right back up! WHAT!?!?
Is this Electrical or Vacuum related?
This also happens in [list]Whenever the vacuum hits 0 lbs @ 3/4 throttle position
        Old Jul 7, 2006 | 07:36 PM
        cookkd's Avatar
        cookkd
              That's exactly what is supposed to happen. The A/C has a cut out relay (WOT) wide open throttle. When you go heavy on the gas, the relay cuts off the a/c until your revs are back to normal.
              Old Jul 7, 2006 | 07:55 PM
              JTHill24's Avatar
              JTHill24
              cookkd:
              That's what I thought too but....The 89 aero that my wife drives doesn't change no matter how heavy or fast you press the gas petal.
              But the 89 I drive does. I think there is a problem with mine when it does it.
              JaY
              Old Jul 7, 2006 | 08:54 PM
              tom_foreman's Avatar
              tom_foreman
              WOT will cause the compressor to shut off. The blower keeps going. The problem you have is vacuum related. I have this problem in my 94 4.0. The air stops coming out of the vent and comes out of the defrost. Vacuum controls the direction the air goes. If you don't have enough vacuum the flap will not stay in the vent position and goes to the default position which is defrost. Check your vacuum hoses, resovior, and check valve.
              Old Jul 8, 2006 | 01:55 AM
              ken1mod's Avatar
              ken1mod
              vacuum check valve. Period.
              ken
              Old Jul 27, 2006 | 01:48 PM
              Maybe's Avatar
              Maybe
              This must be contagious
              Last night mine cut out and shifted to the floor, instead of defrost, as I was accelerating (55mph) up that long hill going home. Is it the same? Vacumn check valve? No rear air on mine.
              I suspected vacumn but thought maybe a hole in a line somewhere as I had this with my Grand Cherokee prior,but it shifted to the defrost .
              Old Jul 27, 2006 | 02:46 PM
              bertha66's Avatar
              bertha66
              ken
              Ken, where is this valve? Allen
              Old Jul 27, 2006 | 05:14 PM
              ken1mod's Avatar
              ken1mod
              mine is at front of engine in line with vacuum reserve tank. tubing looks like wiring.
              Ken
              Old Jul 27, 2006 | 05:56 PM
              bertha66's Avatar
              bertha66
              Thanks, I will have a look, mine 90 Aero has some problems will getting air out of the dash.
              Old Jul 27, 2006 | 09:39 PM
              99f350sd's Avatar
              99f350sd
              Vacuum for sure... could be a leak also.
              Dick
              Old Jul 28, 2006 | 12:25 AM
              Pablo-UA's Avatar
              Pablo-UA
              Vacuum ore actuator, I'm sure. WOT cuts off AC clutch only, but still blows!
              Old Jul 28, 2006 | 10:24 AM
              Maybe's Avatar
              Maybe
              Actually.............nothing cuts out the air flow is just re-directed to the floor from the vents,air is still blowing and AC still functioning.It returns to the vent out-put on de-acceleration. This is something new for the Navy Bean.
              Of course this miserable 90,96+ degree heat with heat indexes of 100+ is very un-usual for here also.I hate it and definitely sympathize with anyone in the awful heat around the countries.
              Old Jul 28, 2006 | 10:37 AM
              99f350sd's Avatar
              99f350sd
              Check vacuum as stated.
              Old Sep 14, 2006 | 09:46 PM
              mrfixit64857's Avatar
              mrfixit64857
              just what, for the uninitiated, is WOT?
              Old Sep 14, 2006 | 09:55 PM
              Mormakil's Avatar
              Mormakil
              Wide Open Throttle
              M
