bio plant in idaho
Old 07-10-2006, 06:42 PM
luvemhot's Avatar
luvemhot
luvemhot is offline
bio plant in idaho
Fab
there was a bio plant that was undre construction burn down in new plymonth idaho was it the one you have been working on?
Old 07-10-2006, 10:00 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Originally Posted by luvemhot
Fab
NO Phew! You beat me to the post. The plant I'm building has a FOAM fire suppresion system built in. ALL the Methanol tanks, mixers, and their pumps etc, are OUTSIDE with a steel roof and foam fire suppresion also.
ALL the excess Methanol is removed by vacume from the glycerol AND the biodiesel. All tanks have a fume recovery system built in, that extracts all the vapors and recycles the liquids.
I am sorry for the loss of life, and grieve for the familys. But as I understand it [ and I've talked with people that where there] They we're welding on the TOP of a tank of Biodiesel, which probably had Methanol vapors in it. The plant did not have a foam fire system, the tank was not purged before welding, the local fire dept did not have foam either. Water only SPREADS an oil fire.
I just hope in the rush to build more plants that people take a long hard look at safety and do the proper planing FIRST so the "Powers-that Be" don't make it harder to start up a biodiesel plant.
FABMANDELUX.
Old 07-10-2006, 10:16 PM
luvemhot's Avatar
luvemhot
luvemhot is offline
We had an engine over there with all our foam and the haz mat team. On my day off so I had to listen. Glad to hear you are building it right. It is unreal how many people dont want to spend the money on a fire sprinkler system. I was first in on a fire last year that the was over 1 millon. I found out later he had looked into a sprinkler system and did not want to spend the money on it. go figure
Keith
Old 07-13-2006, 02:53 AM
kennedyford's Avatar
kennedyford
kennedyford is offline
Coming through Idaho Thursday night Friday morning. Update to Fab and hello to others. Troy. No email Thur or Friday unless I find a hotspot for free....Found your home and shop numbers Fab.
