Looking at a 6.0
You will find guys raving about their 6.0's, but there are a lot of "buy backs" out there too of which I personally know 3. The 7.3 had better off the line pull than the 6.0 and yet is rated lower.
I know also, you won't find the Dodge/Cummins boards filled with the disaster stories you'll find on the 6.0 forums. "The Diesel Stop" is full of good reading on the 6.0.
I went with the diesel for this truck and it has performed well. The 6.0 has *much* more power than my 460 ever had. Towing performance is also excellent - it tows like a mule.
There were reports of problems with 03 and 04 trucks with the 6.0 engine on the internet. Although some folk have had their share of problems, none of my friends who drive 6.0 trucks have had any real problems with theirs.
Just my $.02.
Lou Braun
I also have a 7.3 and I have spent a lot more money on it then the 6.0s but I have 5 times as many miles also!!
You should try to get a 2006 for 2 reasons. First, the 2007 will be the first year release of the new 6.4L diesel. You would be wise to avoid the first year release of any engine from any manufacturer. Second, Ford is anticipating problems with having the 6.4L ready for the 2007 trucks because of emissions issues.
As the EPA continues to tighten the emission regulations for diesels, you can expect the engines to get more complicated and the power and fuel mileage to drop.
Geez, the way things are going with emissions regulations, before too long, the air will be cleaner after your truck has driven through it than it was before you got there.
To answer your questions:
If you get an automatic, the TorqShift is a great transmission which makes a great companion for the 6.0L diesel. There is no way to lockout OD and you don't need to do this anyway. The tranny is definitely built to take the torque generated by the 6.0.
The biggest issue with the newer 6.0L diesels seems to be the oil leaks. There are over a dozen common leaks on that engine and they all show up as a drip on the bellhousing. It is more of an annoyance than anything else but it can be difficult to fix because of all the possible sources.
I have a 2005 F250 6.0 and with 4000 lbs in the bed, the drivetrain pulls like the truck is empty. It runs an pulls great under load.
My friend pulls an 11K lb horse trailer with her 2004 F350 and that rig runs circles around her F350 that has a 460 in it.
By the way, if you visit the Dodge boards, you will find that as stated above, the Cummins is a great engine. But, the Dodge automatic trannys do tend to be a problem. It will be interesting to see what Cummins does to meet the 2007 regs for the Dodge trucks.
Both the product and the warranty are defective.
Back to the question:
whalerron does have the rest covered...with the small leak issue and the TRUE tough 5R100 auto tranny.
However, the problematic factory variable vane turbo charger is questionable. Not just new, but with 150,000+ miles. One reason FORD is switching to a dual (NOT twin) turbo setup on the 6.4L.
PLUS, let's not forget the dreaded "single" EGR valve on the 6.0L. FORD has acknowledged it is a weak link in that engine. Rumors have it...that the 6.4L is going to have 3 EGR valves to help with the plugging up issue. See this FTE link for directions on how to unplug it... https://www.ford-trucks.com/article/...tructions.html
Hope this helps...make a better decision. OBTW, I am not saying to stay away from the 6.0L, but providing information so that you are in the know.
biz
_____________________________
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s
I just read an article about the Duramax and it too uses a VVT Garrett turbo. Buying a Chevy isn't gonna get you around that.
As to the 6.0, there's plenty good and a fair amount bad. The early ones had fuel injector problems. Today one here we hear mostly about EGR valve problems and turbo vanes sticking due to carbon buildup. People on here and elsewhere will be glad to go on and on over what causes buildup. I hold with the folks who attribute it to too much idling and making short trips.
A lot of the problems in 2004 trucks stem from the fact that Ford continued to put 2003 build date engines in the 04s for a while. The 2004 engine had something on the order of 100 revisions. My 2004 F-350 (it came with the 2004 Engine) has performed admirably. It is an excellent tow rig, and it has never been to the shop in 30,000 miles of operation.
As said earlier, the 6.0 is not being discontinued due to reliability concerns. In fact, the replacement 6.4L engine is based off of the 6.0L engine. It's the EPA regulations that are driving all that, just as it was the previous crackdown that killed the 7.3. There are all kinds of rumors flying about regarding the 6.4. More than likely, the new eigine will have multiple turbochargers, multiple EGR valves, particulate filters in the exhaust system, and a new Common Rail Injection system to replace the HEUI system that's been around since the first generation Power Stroke 7.3 engines.
The new Cummins is going to have an EGR system and a Variable Turbo. Ford took the first hit on this stuff with the 6.0, but everyone else is headed for deep waters as well. Despite a big boost in displacement, it is just barely going to meet the performance of the current 5.9L engine, too.
