sway bar drop bracket ?
Old Jul 6, 2006 | 01:22 AM
f150_514ci's Avatar
f150_514ci
ok hear's the deal i had a 4'' lift kit off of a 76 4x4 that i sold to a buddy of mine and i can't seem to find the sway bar drop bracket for him , so i told him i would make one for him . my ? is from the center of the original hole for the sway bar , how much lower should the center of the hole be moved to keep everything lined up ?
thanks
Old Jul 6, 2006 | 08:49 AM
74 F100 351m's Avatar
74 F100 351m
I have made drop brackets for my 74. I put a sway bar off a 78 bronco on it. The 73 has a 78 F250 4x4 frame under it. i have photos of both in my gallery.
Old Jul 6, 2006 | 11:33 PM
f150_514ci's Avatar
f150_514ci
ok but im looking at the center of hole for stock location and how far that center is moved down for the 4'' lift thats what i need . ( old center to new center ) distance moved ?
Old Jul 7, 2006 | 04:11 PM
MBBFord's Avatar
MBBFord
For each inch you lift it, it needs to be a inch longer.
Just weld in a 4" piece to the sway bar links and that's all you need.
Broncograveyard sell some with that are extened 3"s, but are only for lifts up to 3"s, so inch by inch.
Old Jul 7, 2006 | 07:25 PM
STGFordCrazy04's Avatar
STGFordCrazy04
noone sells 4" drop brackets? Im sure I saw some. Maybe Energy Suspension?
Old Jul 8, 2006 | 01:05 AM
bronco521's Avatar
bronco521
i used a skyjacker 6" lift and it came with new drops.they probably have'em for a 4" too.
Old Jul 10, 2006 | 01:08 AM
f150_514ci's Avatar
f150_514ci
hey everybody i'm sorry i meant trak bar . lol was really tired when i wrote that
Old Jul 10, 2006 | 07:04 AM
77460f150's Avatar
77460f150
BDS sells that drop bracket for about $40. It's just a 1"X1" square stock with a couple of holes drilled in it. I will measure mine tonight and let you know the dimentions. I just measured mine and you need to drop the end on the frame by the steering box 3" from original position. Will try to get some pics tonight. -Ed
Old Jul 10, 2006 | 11:18 PM
f150_514ci's Avatar
f150_514ci
ok is 3'' from the center of the original hole to the center of the new hole ? thanks
Old Jul 11, 2006 | 06:17 AM
77460f150's Avatar
77460f150
Yes, that is 3" from the center of the original hole to the center of the new hole. -Ed
PS- sorry no pics last night, my camera is acting up.
HaydenFryGuy
Feb 7, 2022 12:17 PM
Joel Cassell
Jan 12, 2018 10:55 AM
Choptopjimmy
1983 - 2012 Ranger & B-Series
Sep 30, 2014 11:58 AM
brehenkel
Mar 26, 2014 04:15 AM
mooktank
Offroad & 4x4
May 11, 2004 02:53 PM
