Xylene?
Old Jul 5, 2006 | 07:34 PM
markjw's Avatar
markjw
Xylene?
I intend to paint my truck with some "Tufcote 917 Air Dry High Solids Enamel" It is a grey Equipment paint I found at the swap meet.One Gallon of it. It says on the lable that thinning is not required,but if I do thin it, I need to use something called Xylene or T-8805...Cant find either of these items..Can someone tell me if there is a more common, suitable substitute. I will spray it on with a HVLP gun that I have never used. Any tips on spraying equipment enamel would also be appreciated.Thanks.
Old Jul 5, 2006 | 07:51 PM
seventyseven250's Avatar
seventyseven250
Xylene is a common industrial solvent. You should be able to buy it at your local industrial coatings dealer. Probably not cheap though.
Also keep in mind it's carcinogenic, and it dissolves Latex Gloves pretty quick. I think that those more expensive blue gloves keep it out, but I haven't tried it.
Old Jul 6, 2006 | 10:05 PM
mississauga's Avatar
mississauga
Xylene is also used to clean tools and equipment that has been used to apply epoxy paints. As 77-250 says the industrial paint suppliers should carry it.
Old Jul 10, 2006 | 05:08 PM
buffalobob's Avatar
buffalobob
home depot has it
Old Jul 14, 2006 | 10:14 PM
xlrs's Avatar
xlrs
True Value Hardware has it
Old Jul 15, 2006 | 07:44 AM
FortyFords's Avatar
FortyFords
When using
please use proper protection resperators .As we know bad things happen with fumes and lungs .
I've lost a few good friends to lung diesease from painting cars yrs ago,not wearing proper protection
Rich
