Propane Injected!!
Old Jul 5, 2006 | 08:56 AM
caterpillar's Avatar
caterpillar
Propane Injected!!
I just wanted to let everyone know that i have put propane injection in my 89 7.3, and man what a world of difference. First off you notice the power majorly it kicks you back in the seat when you turn it on and second i have noticed i can shift smoother due to the lesser idle down between gears it seams the propane keeps the rpm's up for just a little longer and makes the gears go in really nice. Just wanted to let everyone know, and if they are thinking of doing the propane injection...DO IT.... i did it for not even two hundred bucks tank and all and i bought everything new so i say go for it.
Old Jul 5, 2006 | 10:08 AM
F250FarmBoy's Avatar
F250FarmBoy
Did you do it by that link I gave you? How much PSI are you running and when do you have it activate? Glad it worked out for you.
-stormin
Old Jul 5, 2006 | 03:43 PM
seanvicious's Avatar
seanvicious
does it run constantly with a steady flow of propane being injected?
Old Jul 6, 2006 | 01:03 PM
BOB ROSS's Avatar
BOB ROSS
do you mind posting a parts list for this project?
Old Jul 6, 2006 | 01:29 PM
caterpillar
I did use that link you gave me farm boy, and yes it runs a steady flow of propane at 5psi, the parts i used was as follows:
Single stage regulator, mr. heater accessories to get the regulator to connect to the hoses, about 12 feet of hose, a water shut off valve from the hardware store instead of an electric on off switch this way i control the propane when i want it on and off and then the tank and a milk crate so it has some stability in the back of my truck. cost me less than 200 bucks.
Old Jul 6, 2006 | 04:46 PM
az7.3's Avatar
az7.3
injection link
Caterpillar, Could you give us the link again! For $200 I am going for it asap!!!
Old Jul 6, 2006 | 06:21 PM
seanvicious
http://www.members.shaw.ca/k2pilot/P...20article.html
