Modular V10 (6.8l)
Gas Mileage
Old Jul 5, 2006 | 08:48 AM
dhawk57's Avatar
dhawk57
Gas Mileage
I wasing coming home from Chicago to Michigan this past weekend and while on I-94 at highway speed cleared the MPG indicator and for the next 150 miles I averaged 13.5 miles per gallon. I thought that wsa pretty good since I only have 3,000 miles on my V10 2006 KR. I had the croise set at 72 MPH.
Old Jul 5, 2006 | 09:35 AM
metalman1320's Avatar
metalman1320
I'd say that's pretty good compared to my 12mpg average. Though I think Capt. Charlie did a little better on his trips to the dragstrip the other week. And for some reason, this last tank of fuel that I got Friday 6/30/06, I've gotten horrible mileage. At least according to my fuel gauge. Anyway, yeah I'd love to get 13 plus. Congrats dude!!
Old Jul 5, 2006 | 10:12 AM
dhawk57's Avatar
dhawk57
metalman
I think that your 12 combined is pretty good. remember I set my guage while already at highway speed to get 13.5. My highway city combined prior to that was 11.4. It might be a little better now that I have a few miles on it.
Old Jul 5, 2006 | 10:21 AM
metalman1320
Oops, I didn't realize you set it while cruising. Again, we see what happens when I don't thoroughly read the thread. Thanks for picking up my error. I'd guess though, you should see some improvement over the next 3,000 to 5,000 miles. Anyway, good luck and thanks for the info.
Old Jul 16, 2006 | 08:26 AM
budfans's Avatar
budfans
these numbers seem higher than that of 5.4 guys how does that work out ??
Old Jul 16, 2006 | 08:42 AM
Wrenchtraveller's Avatar
Wrenchtraveller
It works like this. A CC 4x4 LB like mine is under engined with a 5.4 and will get less mileage than a V10.
Old Jul 16, 2006 | 09:31 AM
yomow's Avatar
yomow
I have a 05 Ex. how do you clear mileage codes to check my trip mileage ?
Don C
Old Jul 16, 2006 | 09:41 AM
azdrawdy's Avatar
azdrawdy
Smacking the nail on the head!
My younger brother bought a black '05 F250 CC 4x4 LB with the 5.4 and auto late last year. Said it was what he really wanted. When I was spec'ing mine out and reading these forums, he wouldn't listen to my rationale for purchasing a hard to get V10.
When we talk now about trucks, it nearly kills him. He and I get the same mileage. He started looking at fivers and travel trailers after I got my fifth wheel, and he is pretty darn limited in towing...F250, 5.4, CC, 4x4, LB...?
Michael
Old Jul 16, 2006 | 10:06 AM
TeamMudd's Avatar
TeamMudd
well just as a #'s thing here are the comparisons. if you have a 8-9000lb truck, you want torque to help push that weight. compare the V8 to the V10 in torque and there is your answer. and the bad thing is that most V8 SD's don't come w/ a lower gear ratio (higher #) to compensate for the lack of power.
there has been alot of gear changes that i've read about w/ the V8's that guys have done. from what i read they go to a 4.56, and some go to a 4.88 to compensate. they are running anything from a 33"-36" tire w/ that gear combo, and loving it from what i understand.
like i said that's just what i've read, i don't own a SD w/ a V8 and NEVER would unless the V8 is a PSD.
Jason
Team Mudd Pres.
415cu. in, 6.5 lift, 39.5's, yea that's right 35.5's
Old Jul 16, 2006 | 07:50 PM
bronco521's Avatar
bronco521
yomow-just hit the reset button when the avg mpg screen is showing in the info screen.i've got a 05 ext cab v10 w/4.10's and have gotten a best of 14.1 hand calculated on the highway,75-80 with ac on.
Old Jul 16, 2006 | 10:12 PM
Bagger's Avatar
Bagger
On mine (05 CC 4.10) the AC takes about 1-2 mpg off my total. In my truck the in dash mpg thing is pretty close to hand calculated. I like to have the windows down anyway. it was like 99 degrees this weekend and I still was driving around with the windows down, my wife hates it.
Old Jul 17, 2006 | 12:05 AM
bronco521's Avatar
bronco521
you're tougher than i am.what mileage does yours get?
Old Jul 17, 2006 | 08:30 AM
Bagger's Avatar
Bagger
I just do not like being all sealed up, I am used to bikes and jeeps and It is tough enough just having a roof overhead (I should have gotten the moonroof, the only thing I would change!)
I get about 11.5- 12 mixed. I drive with my foot in it allot. I found that if I get on it I do not use that much more gas. In just stop and go traffic it can get as low as 9 and the best I have ever gotten, thurway station to station was almost 15. From what I have found the AC will use more fuel then my foot (AC -> 1-2 mgs Foot -> .5 - 1.25 mpgs). I do not drag race from light to light but on the tollway 75-80 is normal (I try not to get to 90 too often). I think even when I take it easy I still am not going as easy as some!
Old Jul 17, 2006 | 10:07 AM
bronco521's Avatar
bronco521
i drive about the same.stop and go in town i've gotten as bad as 9.it isn't worth the 1 mpg to drive it like your scared of bruising the gas pedal.
Old Aug 2, 2006 | 11:36 AM
spstruck's Avatar
spstruck
Ever since I got my '99 F250 CC SB 4X4 in April I have had rare opportunity to measure highway mileage since I've either been towing the camper or piddling back and forth two miles to work and back. Last week I took her on an empty road trip (2 lane road 55mph speed limit, cruise set at 63mph, 100 degrees F, A/C running on MAX) and calculated my mileage at 13.7 MPG. My '96 Tahoe I had previously would only get 14.5 on its best day. I was very happy with the mileage.
