Electric fuel pump
Old Jul 4, 2006 | 09:54 PM
workingdog's Avatar
workingdog
Electric fuel pump
As part of moving the fuel tank from the cab to the rear of the truck I'm also changing over to an electric fuel pump - but I have idea about the details.
How many psi does a carb require?
Do I need a pressure regulator between the fuel pump and the carb or one after the carb?
Are electric fuel pumps able to run against a closed bowl? Or do they need the regulator to allow fuel to flow.
Thanks for the help.
Peter
Old Jul 5, 2006 | 03:43 PM
billemc's Avatar
billemc
I think the electric pumps today are self regulating. Once it has the system presurized, it will just maintain that preasure. Correct me if I'm wrong forum. Billemc
Old Jul 5, 2006 | 09:59 PM
67Pustomp's Avatar
67Pustomp
depends on what you buy..most standard pumps are self regulated and have pressure of 4-7 lbs...pumps used for racing have higher outputs 12-14 lbs and higher gallon per hour flow and higher prices..pumps like these require regulators
Old Jul 6, 2006 | 06:17 PM
baitmaster's Avatar
baitmaster
7 lbs
I have used both a NAPA elec pump and a Holley Red pump and both are self regulated at about 7 lbs. make sure you use a filter before the pump!
