fuel tank replacement
Old Jul 4, 2006 | 12:31 PM
bluthunder's Avatar
bluthunder
the side fuel tank leaks if i fill more than half-way. is there any difference between the tank for a gas or diesel truck?
Old Jul 5, 2006 | 08:38 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The pick-up assembly will be different, but the tank itself should work. I think the hole for the fuel pick-up hole in the tank is the same diamater.
Old Jul 5, 2006 | 10:17 PM
fellro86's Avatar
fellro86
Keep a watch on what year, if you want it to go right in no mods, it would seem the 87 up are a shade different. When I changed my 92 from gas to diesel, the locator tabs were located different. Beyond that, it is the same.
Old Jul 8, 2006 | 03:44 PM
bluthunder's Avatar
bluthunder
the pick-up assembly ought to be replaced at the same time i would think. thanks for the info, guys.
Old Jul 9, 2006 | 09:28 PM
dwaymar's Avatar
dwaymar
look at the make of tank some are galv tanks i have ran into this prob so now have plastic tank holds 8 more gallons to
