Oil Pressure Question
My question regards the oil pressure, when started the pressure is 60psi at idle, after warming up to approx 108-190 coolent temp, the oil pressure is pretty much constant at 40psi at most RPMs, but when driving at a constant 2500 RPM and I accelerate, such as to pass, the oil pressure drops off to 30 psi. when I let up on the accelerator the pressure moves up to 40psi again. Is this a normal thing or something I should be worried about?
Dennis
Welcome to FTE!!!
I have a 56 with the almost identical setup. I would worry (and did) when my oil pressure drops like that. Sounds like you are running out of oil at the pickup. Are you running a high volume pump? If you run a high volume pump with a stock pan, you'll pump the sump dry at higher rpm. Is your oil level OK? Mine did that when I was a quart low.
The rule of thumb is 10 psi of oil pressure (min) per 1000 rpm is fine. That's what everybody says, but it makes me worry on a hotted up engine.
I just rebuilt my 351C specifically because of the same problem. I was running a stock pump and pan. Haven't got it back in yet, so I can't tell you more.
And... your comment about it liking racing gas makes me suspect you are running a bunch of advance? Too much advance can damage the rod bearings.
