1978 - 1996 Big Bronco
94 ford bronco shift correction package
Old Jul 2, 2006 | 08:37 PM
mechanixpearl's Avatar
mechanixpearl
i have a 94 ford bronco and i am having some problems with reverse not wanting to engage sometimes and shifting every once in a while.I read a post online that says a shift correction package would fix this problem. i do not have a problem finding the shift correction package but i cant seem to find anyone who knows how to install one.Im not really worried about installing it i just want to know before i buy it you can install it with the tranny in the truck i dont want to rebulid my tranny at this point considering it still pulls well.If anyone has installed one of the in a e40d please let me know. thnx
Old Jul 3, 2006 | 05:14 PM
greystreak92's Avatar
greystreak92
The E4OD does lag going into reverse at times. Its not long but longer than I like at times. With a 94 model yours should have all of the factory upgrades unless its early enough in the 94 model year production run to have the older style E4OD. Ford made some serious changes to this tranny sometime in the 93-94 production run. The updates significantly improved shift pattern and longevity in these units. As for a shift kit, I am not 100% certain as to how far into the tranny you need to delve to accomplish the install but I do know that even the best transmission shops raise their eyebrows when they hear they are going to have to work on an E4OD.
Old Jul 3, 2006 | 05:27 PM
mechanixpearl
Question shift correction kit
www.oregonperformancetransmission.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=OPTI&Product_C ode=SUP-KE4OD&Category_Code=E4OD this is the link for the parts i was talking about it says easy to install?
Old Jul 3, 2006 | 08:09 PM
b4hntn's Avatar
b4hntn
mechanixpearl, you are probably way ahead of me, but did you see the "Contact" button at the bottom of that kit page? Might be worth a try...
Old Jul 4, 2006 | 10:50 AM
RanchRodsTX's Avatar
RanchRodsTX
I have used the TransGo kit that they sell and it does make a huge difference in the E4OD. I have not used the Superior kit.
