light 'clunk'
Old Jun 30, 2006 | 01:02 AM
powerstroke6ltr's Avatar
powerstroke6ltr
light 'clunk'
Got a call from the dealer earlier today, right before the truck left them to get the paint issue fixed, and they told me that the light clunk i hear is normal. I get it when i am turning the wheel right and almost to the steering stop i hear a light clunk. I've jacked up the truck and wiggled the wheel and tried moving things with my hands to make the noise. It happens almost to the steering stop, and if you turn left slightly then back right it'll do it again. It does it stopped and rolling... I suppose it is 'normal' indeed if i found nothing loose and the dealer agrees... Sound right?? thanks!!
Old Jul 1, 2006 | 12:16 AM
reddog99's Avatar
reddog99
One more thing you can check, that I've had happen to me: check to see that the battery is tight. Grab it to make sure that it won't slide around. I once had to install spacers under the battery clamps because they weren't holding the battery firmly.
Pat
Old Jul 1, 2006 | 01:51 AM
rebturtle's Avatar
rebturtle
Originally Posted by powerstroke6ltr
...It does it stopped and rolling...
Well, because of this part, I'd be more inclined to say that something is binding than something being loose. You may want to have a friend steer it from side to side while you watch the front and look for any sudden movements when the "clunk" occurs. Two prime suspects would be the ball joints or a tie rod.
Old Aug 8, 2006 | 12:43 AM
powerstroke6ltr
*Update: turned out to be a loose tierod. I went to the dealer for an oil change and told them if that is 'normal' then demonstrate it on a new ranger. Went out to the back lot and the new one didn't do it, surprising... thanks for the suggestions! (Curious though as to why it did that...)
