power steering problem
Old Jun 29, 2006 | 09:51 PM
justin25's Avatar
justin25
i just finished rebuilding my 79 400 motor, i bought a new steering box and i have it installed, today i had it running and i had no power steering. any ideas whats wrong here??
Old Jun 30, 2006 | 07:18 AM
cujo8's Avatar
cujo8
Possibly air in the PS system. With the engine running you are supposed to turn the steering wheel from lock to lock a couple of times to remove the air from the system. I will be reinstalling my motor and replacing my PS hoses at the same time in the near future. My 77 truck also has a PS oil cooler on it that has quite a bit of volume to it, so when I fill the PS system, I plan on leaving the highest fitting loose as I fill the system to expel most of the air before I close her up. I will then do the procedure I wrote above to remove the remaining air from the PS system.
