Squeeling from P.S. pump
Old Jun 29, 2006 | 02:08 PM
steinbronn's Avatar
steinbronn
well i have a problem. i think my p.s. pump is going bad. I have it full of fluid but occasionally when i am in reverse it seems to have manual steering. any thoughts would be appreciated.
thanks
jonathan
Old Jun 29, 2006 | 04:45 PM
1975Ford's Avatar
1975Ford
Does the engine idle normally when reversing and the power steering system is not operating correctly?
Old Jun 29, 2006 | 06:46 PM
montana105's Avatar
montana105
This may sound like a stupid question but what does your P.S. fluid look like and is it low? My truck was doing the same thing only it did it in both directions,the dealership I worked at had a flush system and I did it to my truck and it's been better then ever since,until one of my hoses developed a leak for no apparent reason other than age,think they were original. John
Old Jun 29, 2006 | 07:00 PM
steinbronn's Avatar
steinbronn
the color was good and it isn't low. but i will try that. also if the belt is to tight could that cause it??? also the engines idles fine.
Old Jun 29, 2006 | 07:26 PM
montana105's Avatar
montana105
Too tight definitely no good,puts to much strain on bearings and does cause squealing nosie,not to much related to what you've described,yours sounds more mechanical.
