Flickering lights
Old Jun 29, 2006 | 01:46 PM
out and about's Avatar
out and about
Flickering lights
I have a 2002 ranger with the 2.3 5speed manual. I've noticed lately that my lights will flicker rapidly on/off during the daylight. I could see the reflection in traffic from the rear of cars in front of me. My headlights work normal though. I tried resetting the computer by disconnecting the battery for a few minutes but the problem still exists. It is not a constant thing, it seems to arrive and stop at random.
Thanks,
Bob
Old Jun 29, 2006 | 07:59 PM
Bob Ayers's Avatar
Bob Ayers
If I understand you correctly, is it only the back lights that flicker? If so, check the ground connections for the back lights. One other possibility, does it have a wiring harness/connector for a trailer? If so, check the wiring for chaffing, and open up the connector and look for corrosion
Old Jun 30, 2006 | 07:40 AM
FTE Trigger's Avatar
FTE Trigger
Lightbulb
Bob, i think its his front headlights that he notices off the rear-end of vehicles in front of him. I still agree with your idea of checking connectors/grounds and some basic wire chasing. That would be where I would start...
Orrr... did you have a DRL module "fudged" in after purchasing the truck? maybe that's on the fritz or it has a bad connection?...
I was also thinking maybe the mutlifunction sw. may have gone haywire too, but you'd notice the "flickering" hi-beams at night.
Old Jun 30, 2006 | 01:19 PM
out and about
It's the front running lights and will do it at random, however, it does it most after starting the vehicle and in traffic. I purchased the truck new. I checked the trailer harness but can't find and damaged wire.
Old Jun 30, 2006 | 08:56 PM
brainfart's Avatar
brainfart
Check the DRL module grouyd wire...
Old Jun 30, 2006 | 09:39 PM
sfcwoodret's Avatar
sfcwoodret
Check for loose fuses
Old Jul 5, 2006 | 04:21 PM
out and about
Turns out to be a bad DRL Module. $115.00 for the part. I unplugged it and left it like that for now. Thanks for the help.
Old Jul 5, 2006 | 06:12 PM
FTE Trigger
Smile
Cool Deal... glad to know you found it! Now...
Old Jan 17, 2007 | 11:23 PM
hotroddually's Avatar
hotroddually
Question
i have the same problem. how did you disconnect the lights? i would like to try the same fix too.
Old Jan 18, 2007 | 06:56 AM
out and about
The module is between the radiator and front driver's side wheelwell closer to the underside .
