Replacing Throtle position sensor question?
Old Jun 29, 2006 | 01:40 PM
fishindave11's Avatar
fishindave11
I've got a 92 F-250 with a 460.
Is there any tricks or special things to do? Or is it as simple as unbolting, unpluging and reinstalling? Please advise.
Old Jun 29, 2006 | 03:23 PM
Kemicalburns's Avatar
Kemicalburns
read www.fordfuelinjection.com
Old Jun 30, 2006 | 01:44 PM
fishindave11
So, I understand it's purpose now, and how it works. I'm guessing there is no trick to replacing it?? Can someone confirm?
Old Jun 30, 2006 | 02:07 PM
andym's Avatar
andym
The TPS is adjustable. You have to hook up a multimeter and get it within specs. There was a thread in here not very long ago that explained exactly what you need to do. Try a search, it was in this forum.
Old Jun 30, 2006 | 04:13 PM
fishindave11
I did a search and had a question. Some say you have to adjust every one, others say that is only true on a 5.0. The general idea was if your screw holes were oval, it's adjustiable; if they are round, it's not. Can you clarify?
Old Jun 30, 2006 | 06:45 PM
Kenneth Sons's Avatar
Kenneth Sons
I have a 95 with a 460 and had to adjust it after installing a BBK throttle body. Mine had the round hole with no factory adjustment. I drilled out the brass sleeve in the sensor and ovaled the holes.
Adjust the position so that the center wire reads less than one volt with the key on and the motor not running. I set it to 0.85 volt, after pushing a pin through the wire. Be careful tightening the screws without the inserts. On mine, if the screws are too tight the sensor changes voltage.
