Sponsored by: Real Truck
Vibration???
Old Jun 29, 2006 | 08:15 AM
wolfe1104's Avatar
wolfe1104
Vibration???
Heres the deal. Right around 38-42 mph I get this vibration that feels like it shakes the whole truck. I've had it into the dealership and they balanced the tires but said that it was most likely the tires. Since then ive gotten completely different type of tires and its still the same. Just recently ive noticed though that during the vibration, when i look in the rear view I can see the bed and it had a real bad bouncing motion. so im wondering if this might have something to do with the rear springs. what else could i check. iv already checked all the u-joints, carrier bearing, pinion. all seem to be tight.
Old Jun 29, 2006 | 09:17 AM
KINGKEITH's Avatar
KINGKEITH
I had the same problem. U-joints seemed good until I finally took the driveshaft loose. Then you could tell the rear most joint was bad.
