Looking for a new set of shocks since I still have the originals in the back and the Gabriels up front has one of the bushings gone. I use the truck as a daily driver with not much towing or heavy hauling. I wouldn’t mind it if I still had the OEM ride to it but a little firmer is ok I guess. I have about 65k on the truck now with about 25K on the Gabriel’s before the bushing disintegrated.
What kind of ride does the Monroe Reflex give? I see a few recommendations for those.
Though the signiture was going to be shown for some reason. My truck is a 99 F150 XLT Super Cab, 4X4, 5.4L, with the standard payload
Don't mind me - I just had to play with the new smilies.
Seriously though the ride will a bit stiffer with the reflex than stock but I think any shock you put on there now will be stiffer than the worn out stock ones.
However, the first off camber bump you hit while pushing it through a turn w/ the Monroe reflex will make you . And the first time you hit the brakes hard and notice hardly any nose dive will make you pretty happy as well. Also I believe the Monroes come with a 30 money back guarantee.
Tim
Reason: typo correction
I have the Reflex on for 3 years now and they ride the same. I checked out many options and weighed the performance, price, reliability and these were the best for the money and have proved it.
i got the monreo reflex on the front ant monroe load adlusting on the back. so far i like the ride a little stiffer then the stock, but if you dont' haul much in the back i would stay away from the load adjusting.
