Depends on how you use it. If you do a lot of towing, or out in the mud and water a lot, you probably ought to service it every 30,000 or less. If it's a pavement princess grocery getter, maybe 100,000 interval is sufficient.
If they don't and you are running the synthetic, then you shouldn't have to worry about it until 100K.
If you are routinely in water / mud that comes over the end of the axle tubes, then you are gonna want to do it more often and 25K is not unreasonable.
It's all in how the truck is used. But at $72 for 4 qts of Motorcraft Synthetic 75W-140, you'll figure out real quick how often you need to change it. Man, I'm glad I don't have the LS in the back any more and can run regular old gear oil (just had to put in a $800 locker ).
Mine was 50k, but I changed it everytime I submerged it with hot axles...
I used to try and wait for the axles to cool down before I went through water, but unfortunately that can't always be done. I did move the transfer case and diff breathers up higher - one of the first things I realised when I went through water was that the transfer case filled with water!!!
I launch boats and waverunners with mine. Alot of the time, I launch and pickup waverunners by backing in until the tailgate is under so we can just pull them up since I usually pull due to a dead engine. With my old '96 F-250, I learned the hard way about the vent tubes. One of the first things I did with my '06 was to reroute the vent tubes from the rear diff, tran case and front diff to the same spot up under the hood. Was a bear to do, but well worth it IMO. I also used silicone sealer when I put the lines on just to be sure. I had it backed in 5 or 6 times already and changed the rear diff twice just to check things and no water either time.
Customz,
I am into preventative maintenance in a major way. I abuse my truck pretty hard, and maybe overmaintaining it makes me feel better. I have a Detroit in the rear of my truck, 4.30's, and Mag-Hytec diff. covers front and rear. Even though the diffs have extra capacity, I still don't let the gear oil go over 30k. That goes for the the trans. and transfer case also, even with the Mercon sp at 17.00 a qt. BTW, I pressure wash and maintain underneath my vehicles as well as the sheetmetal, I love it when people ask me "you ever off-road this thing?" and then whip out pics of it in sand, snow or mud!
I've just finished rebuilding my 4R100. While I was at it, I decided to drain the transfer case. What came out was a beautiful golden color. Obviously, it is not a standard Mercon ATF. Now, I'm wondering what it was because it was so nice and clean, I want to go back with the same stuff. Any ideas?
Maybe just a little. I'm thinking it must have been a synthetic or synthetic blend. It's also possible that it was just a premium light gear oil. I got the truck with 120,000 miles on it. That was 88,000 miles ago. It's a '99 7.3. I'll be filling both cases up tomorrow and taking it for its first test run. Pray for me...
I went back with Royal Purple. Now I just have to decide when I'm going to do the first oil change on an overhauled transmission. I'm using O'Reilley's house brand fluid for this first break-in period. I don't know if I should wait 10,000 miles or go for a full year before I swap it out for synthetic. I'm not even sure if I should go full synthetic. It becomes a question of change it more often or go longer with a synthetic. Which is best? Which makes more sense?
my first change was when i changed my gears.........at 25K! i then changed the fluids again at 50K after towing a truck and trailer from NC to LA. now i plan on every 50K, since it's driven daily, and starting in March it will be towing a race truck at least 2x a month till SEPT.
