motor mounts
Old Jun 28, 2006 | 10:11 AM
chopper_53e's Avatar
chopper_53e
motor mounts
The motor mounts for a 460 that Jeg's and Summit have say they will not fit lincoln motors. What is the difference with the lincoln motors?
Old Jun 29, 2006 | 04:20 PM
chopper_53e
Anybody???
Old Jul 1, 2006 | 12:39 AM
460 Crew's Avatar
460 Crew
I used L&L's and have a lincoln 460 and it worked fine. Couldn't tell ya on the jegs or summit setups. Are you talking about the trans-Dapt brand? I was curious about them also. The last 460 I put in recently into a 77.5 I used Autofab mounts...Very nice quality.
Old Jul 5, 2006 | 07:14 AM
William's Avatar
William
Chopper, Post your block number (D1VE)? Lincoln used a huge engine back in the day and I do not remember the CI but it was over 400. The later 429 and 460 blocks are the same for all FMOCO applications. If you are installing a 460 in a truck, Ford made the best mounts (IMHO). These mounts are plentiful and cheap. Post a little more information about what you are planning and maybe we can help.
Old Jul 5, 2006 | 11:06 AM
airharley's Avatar
airharley
Lincoln had a 430 and 462 which was a totally different motor all together from the 385 series. The compression ratio was determined by block milling. I have a Lincoln 460 and it is identical to the Ford.
