Modular V10 (6.8l)
Power Difference
Old Jun 27, 2006 | 11:07 PM
grumpyoleman's Avatar
grumpyoleman
Power Difference
Does anyone know what is done to the 3 Valve V10 that gives the F series trucks 362 hp and the E series Vans 306 hp? I have a 2006 Class C with the V10 and would like the extra torque and hp is it can be done.
Gary
Old Jun 28, 2006 | 01:19 AM
NoMo's Avatar
NoMo
I believe the vans get the old 2-valve V10 whereas trucks get the new 3-valve engines.
Old Jun 28, 2006 | 05:53 AM
captchas's Avatar
captchas
Guest
3 valve parts are many and very costly. heads, valve covers intake manifold. vac. plumbing, exhaust manifolds , cam shafts,pcm. and alot more. drive it the way it is.
Old Jun 28, 2006 | 06:18 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome grumpy, to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jun 28, 2006 | 11:28 AM
krewat's Avatar
krewat
The general consensus is that to get more power from the 2-valve, upgrading to the 3-valve can't be done without lots of money and time.
The generally accepted way of getting more power from the 2-valve motor is a supercharger. With minimal boost, it should easily surpass what the 3-valve would get you. Whether or not you want to put a blower on a motorhome is a different story
OH, and WELCOME to FTE! You came to the right place for V10 info
Old Jun 28, 2006 | 11:40 AM
Monsta's Avatar
Monsta
Sit. Stay.
Let me take numbers & engine designs out of this and answer the basic question.
Vans are depowered via the PCM. They get a different code written for their engines. Two reasons: 1. the intake is somewhat more restrictive & 2. the cannot dissapate the heat as well as the trucks due to the smaller engine compartment.
Old Jun 28, 2006 | 12:14 PM
krewat's Avatar
krewat
Monsta, VERY good point about the heat. Forgot about that one.
