Clutch Slip
Old Jun 27, 2006 | 10:29 PM
IDIFREAK's Avatar
IDIFREAK
Cool Clutch Slip
I Have a 92 F-250 With a 7.3 IDI, 5 speed ZF trans,
I replaced the slave cylinder and it ran fine for a few weeks then the clutch started slipping. When I start Driving the pedal feels normal, After 20 miles the pedal is to the top, no free play, but it has not slipped for a week or so, is it the clutch or the master or slave?
Old Jun 28, 2006 | 06:24 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts!
See you on the boards. ….
Old Jun 28, 2006 | 10:50 AM
wickymustang's Avatar
wickymustang
Did you properly bleed the system after replacement? When you say the clutch is slipping do you mean under load in gear the clutch is slipping or when you try to use the pedal ut usn't properly releasing?
