Electronic ignition conversion question
Old Jan 12, 2001 | 05:26 PM
otto's Avatar
otto
so if i put the pertronix setup on my 75 390 i would have to install a ballast resistor or just install it ?
Old Jan 13, 2001 | 01:59 AM
karljay's Avatar
karljay
The Pertronix kit has all the instructions to determine this. I've been told that Ford uses a resistor wire, but I'm not sure of this.
If you just install the Pertronix converter and no coil change, I think you just install it and don't change anything. Just make sure the read the instruction, but it is straight forward. The instructions basically say: if you have a resistor on already, use it, otherwise don't.
Old Jan 13, 2001 | 08:02 AM
StockMan's Avatar
StockMan
CraigGalloway
Jul 25, 2008 08:51 PM
Hercmech
13
Feb 13, 2007 02:53 AM
Terry M
Alaska Chapter
Sep 13, 2006 12:07 AM
psdinalaska
New Member Introductions
Oct 23, 2004 08:54 PM
71f250_aka_beast
Jan 21, 2001 04:57 PM
