Nope, no need for BK. BioD is very astringent - it cleans as it flows thru the fuel system. So all the gum and varnish that've collected on the inside tank walls and fuel lines get washed into the filter. If you run bioD, consider changing the fuel filters after the first month. Second, the lubricity is far better than dinoD, so there's no need for Stanadyne lube additive, or any other aftermarket lubricant (Lucas, ATF, etc, etc, etc). Finally, the cetane of most commercially available B20 is around 53, definitely better than the 47/48 that we see here at the pumps in east TX. As you can see, bioD is an outstanding choice of fuel - it cleans, it lubricates, and it burns better and cleaner. Anything you try to add is just wasting $$$.
What about the Cetane and other additives in Diesel Kleen, beyond just the fact that it adds lubricity to the dino diesel?
Same power to be expected with Biodiesel?
Cetane number for DK or Stanadyne depends on how much you use. BioD ignites faster (higher cetane #), but has less btu's per unit than dinoD. Realistically, it turns out to be a wash - a longer-duration, steady push on the piston. Some folks report better mileage, some report worse; same with the 'seat of the pants' power impression. All state that the engine runs quieter and there's less smoke under acceleration.
