Sponsored by: Auxito
VIN code question - 1998 F250
Old Jun 27, 2006 | 03:13 PM
FA_Meteor's Avatar
FA_Meteor
Hi,
I was looking at a 1998 f250 today and ran a vin code inquiry (https://www.fleet.ford.com/maintenan...ls/default.asp) to see what the GVWR rating was. It says it is a class 7, 26,001 - 33,000 Pounds range. The other f250's I looked at were listed class f, 7,001 - 8,000 Pounds. These are not the super duty size trucks and look just like the f150's in those years. Is it possible that this truck has that stout an axle in it?
Old Jun 27, 2006 | 04:23 PM
92merc's Avatar
92merc
It depends if it was the HD or the LD 250. The Light Duty 250 was an F150 with axle and suspension upgrades mostly. But yes, the LD250 has a stronger axle than the same year F150.
Old Jun 27, 2006 | 07:56 PM
LxMan1's Avatar
LxMan1
It should be about 13,500. About 7700 GVW
Old Jun 27, 2006 | 08:53 PM
kspilkinton's Avatar
kspilkinton
In that time frame some of the letters for brake designations overlapped. Due to this you can't always trust the decoder... especially when it spits out numbers like that.
F250LDs had 10.25" rear axles... the biggest on an F-150 of that time frame was the 9.75." It also had stiffer/higher rated springs on all four corners. A thicker frame, bigger brakes.... tell me when to stop. The vin should say F or P for the fourth digit for the brake class, type (hydraulics or pneumatics; abs, four wheel rear wheel - restraint type - belts with or without airbags). That one letter has a lot of meaning. For you situation it means 7,001-8,000lb hydraulic, rear wheel abs, both driver/passenger air bags.
With 250LDs I'd advise seeing trucks in person and looking at the jamb sticker for the gvwr. F250LDs can have the 'F' in the vin and still only have a somewhat low 7200gvwr in some trims.
-Kerry
Old Jun 28, 2006 | 06:50 AM
FA_Meteor's Avatar
FA_Meteor
Thanks for those replies folks.
Kerry, that was the info I was looking for. It was hard to believe the gvrw the decoder reported...lol. The front end of the vin is 1FTPX28L2W. So it is a "P" code. I have to go back this week to take a test drive so I'll be able to see the door jam sticker. It did have a larger lug pattern on the rear axle, 7 or eight lug I think (definitely more than five).
Thanks again for all the help.
Paul
Old Jun 28, 2006 | 09:20 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt
Former Vendor
I can run the vin for you. Sould come back with all the info you would need. I'll give you an Oasis too.
Ed
Old Jun 29, 2006 | 10:25 PM
LxMan1's Avatar
LxMan1
Yep, it should be 7 lug front and rear.
Old Jun 29, 2006 | 11:33 PM
kspilkinton
A while back I wrote Ford about any possibility of an 8 lug '97-'99 F250LD... they said none. Parts houses do claim to have parts for them... but who knows what they really have.
-Kerry
Old Jun 30, 2006 | 03:09 PM
LxMan1's Avatar
LxMan1
Nice work of the new smileys, Kerry
brd7666
Feb 1, 2011 01:15 PM
OutlawNomad
Mar 5, 2010 03:16 PM
30coupe
2004 - 2008 F150
17
May 30, 2009 08:43 PM
4inchlovin
Dec 8, 2007 03:06 AM
ruddy
Bronco II
Sep 22, 2005 09:55 AM
