Sponsored by: Auxito
stals when put in gear
Old Jun 26, 2006 | 10:50 PM
reelf150's Avatar
reelf150
Question stals when put in gear
My 2000 f150 4.6 - stalls when placed in gear. this started 2 weeks ago when out of town. I took it to a ford dealer and they said it was a fuel idel valve and they replaced and the problem went away. Today it started all over again. It starts fine and idles fine accelerates smooth until I put it in gear and it stalls. Could the valve be bad already? What would cause this ?
Old Jun 27, 2006 | 03:04 PM
LxMan1's Avatar
LxMan1
The valve could be sticking. Will it stay running if you give it a little throttle when in gear? If so, it is probably a faulty IAC valve and I would have them replace it again.
Old Jun 28, 2006 | 02:11 PM
reelf150's Avatar
reelf150
thanks
Yes it will ! Thanks for the info. I'm going to talk to the dealer tomorrow. Thanks again!
Old Jun 29, 2006 | 10:15 PM
LxMan1's Avatar
LxMan1
Did they get it fixed?
Old Jun 30, 2006 | 09:52 PM
reelf150's Avatar
reelf150
stalls
No they said it is in the trainy's torque converter, my fluid is pretty dirty and they said I needed it flushed but when they hooked it up to flush and put it in reverse they said the pressure went up to 92 lbs and it shouldn't have gone above 20 lbs. Of corse their trainy guy is on vacation. I guess I'll wait and see and talk to as many people as I can till then.
