4x4 flashing lights
Old Jun 26, 2006 | 04:05 PM
d-schmidt's Avatar
d-schmidt
4x4 flashing lights
hello,
I am having a problem with my 99 explorer, the 4 wheel indicator lights come on and flash 6 times then go off, no particular time frame, sometimes once a day sometimes a couple of days appart. It is not in 4wd when this happens. both 4 high and 4 low lights flashhttps://www.ford-trucks.com/forums/newthread.php?do=newthread&f=32#
Old Jun 29, 2006 | 05:25 PM
realtormangold's Avatar
realtormangold
i'm having the same problem with my 98 explorer 237,000 miles both high and low light flashes. also the o/d light flashes about once a day and it starts to shift rough for a while then its fine. i'll fix it soon but if anyone had the same and wants to fill me in im all ears.
Old Jul 2, 2006 | 12:41 AM
savagefan's Avatar
savagefan
Disconnect and check the harness connector at the transfer case clean dirty contacts and push firmly back together. When the light flashes is it 6 times in a row?
Old Jul 2, 2006 | 11:41 AM
d-schmidt's Avatar
d-schmidt
fashing 4wheel indicater lights
yes the flashing lights work at same time and in unison. flashing sequence is over within 4-7 seconds. Repeats sequence after driving a mile or two. It would appear that ford is attempting to tell me something with this silly-ness but ?????? Anyway thanks, I'll try the suggestion.
Old Jul 12, 2006 | 12:11 AM
CMCOBERLY's Avatar
CMCOBERLY
Did you ever get this resolved and if you did what was the problem? I am having the same problem with my explorer.
