69 351w block
Old Feb 25, 2001 | 08:25 PM
82flareside's Avatar
82flareside
69 351w block
I found out the 351w from a 74 Galaxie I put in my 82 flareside is actually a 69 engine. My engine guy said that was good. What is the difference with the 69 windsor?
Old Feb 25, 2001 | 08:37 PM
chilly390's Avatar
chilly390
69 351w block
The '69 blocks have a shorter deck height and thicker main webs than post '72 blocks.
Old Feb 25, 2001 | 10:08 PM
johnny6958's Avatar
johnny6958
69 351w block
The 69 - 74 351 windsor heads have bigger valves and use bigger spark plugs. Autolite 45s if I'm not mistaken. They flow the air fuel mixture in and out of the combustion chamber much better.
Old Feb 26, 2001 | 05:21 PM
onebad40willys's Avatar
onebad40willys
69 351w block
351w Head's don't change to much untill 75. When the 302/351w start using the same head casting. But you have a beefer block.
Old Feb 26, 2001 | 08:06 PM
hillbillyk's Avatar
hillbillyk
69 351w block
Is it a 4v motor, if so it came with 290 factory horsepower.
Old Feb 27, 2001 | 12:31 AM
meatybtz's Avatar
meatybtz
69 351w block
