I messed up! VB help!
Old Jun 25, 2006 | 01:39 PM
wcklew's Avatar
wcklew
OK I was in a rush and took off the wrong vavle body!!! Started to poor down rain and I rushed. So it won't shift unless I let off the pedal. Where do the 3 check ***** go? I thought I put them in them correct spot but it won't shift.
It was the one in front of the VB in the middle next to the electronics. Any one have a ATSG manual please email the page to wcklew@yahoo.com
Old Jun 25, 2006 | 01:52 PM
stuart1's Avatar
stuart1
Um
What are you working on?
A Maytag?
Old Jun 25, 2006 | 01:57 PM
Medic 66's Avatar
Medic 66
WOW. How did you get that email to show up?
Old Jun 25, 2006 | 01:58 PM
wcklew's Avatar
wcklew
1999 f250 7.3 4r100
sorry that might help!
Old Jun 25, 2006 | 02:10 PM
wcklew's Avatar
wcklew
I need to know where the lower control valve body check ***** go back on the main body. I found 3 ***** but have no clue where they came from.
Old Jun 25, 2006 | 02:11 PM
stuart1's Avatar
stuart1
Hang in there I'm looking through my stuff
Old Jun 25, 2006 | 02:34 PM
wcklew's Avatar
wcklew
Stuart1
You're a life saver. I don't know If this helps, but I but in a Bully Dog shift kit.
Old Jun 25, 2006 | 02:41 PM
stuart1's Avatar
stuart1
You are probably the same dude.
Old Jun 25, 2006 | 02:45 PM
wcklew's Avatar
wcklew
So I'm missing a couple *****. Where do I buy those things? Thanks
Old Jun 25, 2006 | 02:46 PM
wcklew's Avatar
wcklew
could you email the picture to me so I can see it better?
wcklew@yahoo.com
Old Jun 25, 2006 | 02:58 PM
cangim's Avatar
cangim
Man that sucks, if you don't have any tranny assembly lube you can use petroleum jelly in its place. Did you take the gasket down as well? or just split the control body?
Old Jun 25, 2006 | 03:20 PM
wcklew's Avatar
wcklew
I just split the body then, figued out I was rushing and removed the wrong one! I cut open my drain pan and found one so I need one more and it's raining again. So I'll see if the tranny shop here will sell me a ball if not I'll call Brain's Truck Stop for one.
Old Jun 25, 2006 | 03:26 PM
cangim's Avatar
cangim
Did it bounce off in the drive way? I guess what I am getting at is if you had three, put three back in and now only have two, we have some serious problems. Do you have the diagrams needed to put them back?
Old Jun 25, 2006 | 03:38 PM
wcklew's Avatar
wcklew
I need bigger diagram then what was posted. There' is 5 check *****, I had 3 then found the 4th in the drain pan. I'll see if a local tranny shop has the 5th plus some extra's.
Old Jun 25, 2006 | 03:55 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
wcklew@yahoo.com
I e-mailed you the IPB off my DVD. It might help.
