Oil Pres Problem
Old Jun 25, 2006 | 09:46 AM
lm853's Avatar
lm853
Oil Pres Problem
Helping with a 1978 302 in a F-150 . Just rebuilt, punched .040, heads reworked, bigger cam, intake, & carb, h/v oil pump. Engine is awsome for short while, then loses oil pressure. Tore down to find oil galley plugs behind timing cover blown out, replaced galley plugs, cam, lifters, push rods, oil pump. Had 50 psi while priming pump, great pressure while setting timing & loading trk, but after short shutdown no pressure when restarted. We are getting some oil pumped but less than 10psi at pressure guage (pulled line off back of mech guage). Suspect galley plugs blown again. Any suggestions as to why?
Old Jun 25, 2006 | 02:39 PM
Beast12's Avatar
Beast12
Hi and welcome to FTE! This forum is for introducing yourself. You should scroll down to the 5.0L (302) engine forum. Someone there should be able to help you.
Read this for some info that will help you around the site: https://www.ford-trucks.com/forums/s...92&postcount=2
-Matt
fvimage
New Member Introductions
Aug 9, 2017 06:36 PM
1990F150w351w
Nov 22, 2007 03:56 PM
mrmata
Feb 26, 2001 05:17 PM
