2001 7.3PSD Excursion
I have no idea if this is a cps problem or what but here's the deal:
When I'm backing into a parking space and shift from drive to reverse she bogs down and stalls. This problem is getting more frequent but does not happen everytime. It only happens in reverse! She starts right back up and backs fine immediately after everytime this happens. She's on her second tranny for 30k miles. I've towed light loads at highway speeds only twice since the replacement.
Thanks in advance for any advice.
NANTRUCKIT, Hey I was told when your IPR injection Pressure Regulator is going bad that is exactly what will cause your problem. The clear give away is you going in reverse. Check to make sure that your washer and nut are on there, and check for loose connections.
Yeah, I'm a little confused too. What would the IPR have to do with stalling in reverse? You say the clear give away is that he's going in reverse. How does reverse only get affected by the IPR?
Stall when engaging transmission (automatic, usually manual low or reverse):
Torque Converter Clutch.
This may be caused by the TCC being engaged at idle. On trucks built before 9-20-95 the correction is a new transmission front pump and/or torque converter. On trucks built after the above date, it could be cause by a loose transmission filter. In this case, install a flat magnetic strip (from a Tempo ATX or Ranger A4LD transmission) in the trans pan below the filter pick up to retain the filter in place or use an updated filter from Ford that has bumps cast into the plastic to help it stay in place.
For further clarification of your problem, does it happen immediately when you put it into reverse, or can you put it into reverse at idle speed and it stalls the truck when you try to give it some throttle? Does it do it all the time, or only if the transmission is specifically cold or hot?
Good question...I knew I wasn't clear enough.
I can put it in reverse and it idles just fine. It's when I give it some throttle that it bogs and stalls. It seems to do it no matter what temp the trans. is at.
It never ceases to amaze me the amount of stuff I learn every time I post on this forum.
Thanks to all!
Just trying to cover all bases here, but have you checked the fluid level in your trans to be sure there is enough?
Yep. The stick says I'm good to go. I'm really stumped as to why it only does it in reverse. I'd think if there was a CPS issue, or injector issue it'd do it in any gear. As I said before the tranny is fairly recent and completely babied since it was replaced. The only other thing I'll mention (and this is more than likely pure coincidence) is that the truck stalled for the first time back in March about 8 weeks after I installed my Tipton chip. After that first time it seemed to happen once every couple weeks, then once a week, then once every few days, and now it does it about once every day or so.
The chip has no tranny tunes that I know of as the tranny is stock. Go figure?
There is a nut on the back of the IRP. This nut sometimes comes loose and causes a stalling in reverse problem. Check to see if it's loose or fell off.
Ok the IRP has a magnet cylinder on a shaft rod and that cylinder has a magnet on the back of it that registures a measurement to the injection system. That washer and nut holds that cylinder close to the base of the unit. Mine was missing the washer and nut all together, the only thing holding it to the unit was gummed up oil. I do not know the specifics but my mechanic at the international shop told me that they are nictorious of this problem. So I would check to make sure that the washer and nut are on there tight and also the electrical clip has no nicks or damage, make sure there is a good connection. The unit should be right below your HPOP resivor on the right lower side.Hope this helps.
Is there any chance in hell that there is a photo of what you are talking about anywhere on this site? I've looked where you described in relation to the hpop and can't seem to find anything like you've described. Sorry to be the idiot but it seems I need a picture drawn
I hope I can eventually find what you're talking about 'cause it sounds exactly like my problem. Thanks for all the help!
NANTRUCKIT, its ok I say the same thing all the time pictures say a thousand words. I am at work so I can not show you a picture. You can call me and I will coach you through it. Or I can try my best to email you alot better description which ever you prefer.
Robert Paquette
Driver Operator WPG Fire Department
623-687-1055
