Inline Six wont start after points changes
Old Jun 24, 2006 | 03:59 PM
fusioncom's Avatar
fusioncom
First question first when I measure the gap for the points on my INline 300 do I measure while the point mechanism is on a flat surface, or on the corner?
I replaced the points, condenser and distributor cap.
Now the truck wont start at all. It has an Accell Coil Pack with an external resistor bar.
With the ACC on I receive 12 volts to both sides of the resitor bar that connects to the coil pack.
However during starting operations I receive no spark from the coil pack.
I wasnt sure if there is a way to test this coil pack or not?
I'm new to points based setups since I was an import guy before so any guidance you guys can provide would be great.
On the Inline six are the pistons ordered 1-6 front to back?
Old Jun 24, 2006 | 04:03 PM
fusioncom's Avatar
fusioncom
One other thing I forgot to mention. The dwell shows up as 8 during starting.
Old Jun 24, 2006 | 06:44 PM
Kruse's Avatar
Kruse
Measure the gap when when the rubbing block is on the corner. (lobe)
Piston #1 is toward the front of the engine.
Old Jun 25, 2006 | 07:51 AM
thefonz#1's Avatar
thefonz#1
Dwell should be 37
Point gap should be .027 --set on the "corner" or "high point" of the lobe
lrd56
Engine Swaps
23
Mar 7, 2016 07:07 AM
BobbyB
20
Jan 13, 2016 02:51 AM
white cat
1983 - 2012 Ranger & B-Series
Oct 21, 2014 11:54 PM
my99ford
Feb 27, 2008 02:58 PM
blackbast
May 27, 2007 09:21 PM
