Sponsored by: Auxito
Changing coolant????
Old Jun 24, 2006 | 02:55 PM
ldcattle's Avatar
ldcattle
Need help changing the coolant in my son's 99 F150 4x4 with Off-Road package & a 5.4 V8.
I can't locate the radiator drain valve. I removed the front skid plate thinking it would be right there. It wasn't. The radiator seems to be smooth all across the bottom.
My 99 F250 SD with 5.4 is on the drivers side bottom, not this one.
Anyone that can lead me to it I'd appreciate it.
Thanks
Old Jun 24, 2006 | 03:43 PM
beer boy's Avatar
beer boy
coolant
if i was having this trouble i'd try the clamp on the btoom rad hose. hopefully when you take the clamp off it leak and the you can use a small flat head screw driver to work around the edge until you can get a manageable leak happening. the drain **** should be there though. take the rad cap off and then reinstall it to slow the "leak". remov it if you thik that your catch pan is in the right spot. thats what i'd do if i couldn't find the drain.
Old Jun 25, 2006 | 05:16 PM
ldcattle's Avatar
ldcattle
Come on....somebody has got to know where the drain valve on my son's truck is located!
Old Jun 25, 2006 | 05:54 PM
jrlowscot's Avatar
jrlowscot
On my 97 it was a white hex on one corner. Not right on the bottom but on the side near one corner it opens towards the engine, be careful I broke mine when tightning it up too much with a socket.
02 Super Duty Guy
Sep 11, 2014 10:05 PM
Mikey_23_ny1
Nov 8, 2010 04:09 PM
davisenvy
Aug 17, 2007 07:17 PM
01' Super Crew
1997 - 2003 F150
Mar 6, 2003 09:26 PM
fishinbum
Jul 25, 2000 08:52 AM
