Sponsored by: Real Truck
Headlights
Old Jun 24, 2006 | 04:26 AM
Aussie SuperDuty's Avatar
Aussie SuperDuty
Headlights
Hi there guys, I have just bought an 06 F250, and seriously, it has the worst lighting I have ever known. You can barely see up the road, out on backroads at night. Our Australian lights are the same as your 03 SD's so what can I do?
I am pretty keen on converting it all to 06 HD lights grille etc, but being in Australia, it could prove somewhat challenging.
Any ideas?
Old Jun 24, 2006 | 06:03 AM
HeavyAssault's Avatar
HeavyAssault
You could try replacing the stock bulbs with some Sylvainia Silverstars and an upgraded headlight harness. There are several sponsors that sell both and would help you. The conversion is a different story. Your biggest decision is cutting the header panel or swapping out the panel and lights.
Old Jun 24, 2006 | 06:49 AM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
I had the same problem as you.
I fitted 2 Hella Predator's to my bullbar. A pencil and a broad beam. Was like turning night to day...
Old Jun 27, 2006 | 12:07 AM
Aussie Pete's Avatar
Aussie Pete
I'm not sure what's going on - if you have an 06 SD in Australia it should have 06 lights - unless of course you bought the Brazilian truck (Ford Australia model?) which is a crock and isn't an 06 anyhow. If that's the case the best fix is to convert the lights to HID bulbs - www.xenonoz.com.au
Old Jun 28, 2006 | 04:18 AM
A. Michael Foxtrot's Avatar
A. Michael Foxtrot
Are they dim or just not directed out far enough? Have you checked to see if they are out of alignment?
Old Jun 28, 2006 | 06:09 AM
captchas's Avatar
captchas
Guest
http://www.automotivelightingusa.com try this company they have better bulbs and hid kits at good prices
Old Jun 28, 2006 | 05:32 PM
Aussie SuperDuty
Well the alignment is good, but they are dim, and dont seem to project as far as my other Falcons here. They look hust like the old lights in my 84 F250.
I would have thought for such a big truck, they would be better.
Are the later ones better?
Old Jun 28, 2006 | 05:35 PM
BigF350's Avatar
BigF350
FTE Emeritus
In 05 (American model) they improved them... but you are right the stock ones suck - especially compared to any Australian built vehicle.
Old Jun 28, 2006 | 06:03 PM
Aussie SuperDuty
You are not wrong. I have 2 98 XR8's here, and they have the smallest headlights ever fitted to an Australian vehicle, and not known for being well lit, but they smoke the Truck for lighting. I live in a semi rural area, where there is no street lighting, and its not the best.
I think later lights could be the go?????
Old Jun 28, 2006 | 07:32 PM
tdister's Avatar
tdister
Am I to assume they are sealed beam 6054 types then (glass, and all in one unit vs. seperate plastic lens and then the bulb)? There are plenty of options that are cheaper than the NA '06 conversion if that's the case. Unless you want the looks I really haven't been impressed with my grandfathers '06 SD lights either. They are a little better than his '04 but not worth the $$ to upgrade considering the other possibilities.
I believe we have diff. regulations regarding light distribution. Our lights are required to shine a certain amount 'up' to light-up overhead road signs, so some of it is lost. I know much of the world does not require this.
If you don't mind the looks, the sealed beam is the way to go IMO (assuming that's what you have). The plastic type will get yellowed/fogged eventually and you'll still have the NA distribution (not good compared to most places). A well designed sealed beam will be just as good, if not better.
I've heard good things about these:
http://www.arbusa.com/ipf_lights_australia_international.htm
Old Jun 28, 2006 | 08:40 PM
BigF350's Avatar
BigF350
FTE Emeritus
These are what I ended up putting on mine:
http://db.hella.com.au/cgi-bin/catal...er&flrecid=684
Do you have a bull bar to mount them on?
Old Jun 28, 2006 | 10:16 PM
Aussie SuperDuty
Great lights the Predators, was looking at putting 2 spreads, and a pencil on actually. I dont have any form of bar on it yet, only had it 2 weeks today...lol, 2300k and loving it though. Still looking through every american site I can find to look whats available.
I actually just picked up some 20's of an 05 Harley F250. Should look good.
Show us some pics of yours mate.
I will go take some pics now of mine and post them
Old Jun 28, 2006 | 10:55 PM
BigF350's Avatar
BigF350
FTE Emeritus
This was it before I had a bullbar/lights and a snorkel:
https://www.ford-trucks.com/user_gal...&albumid=13547
I don't have her any more though (sold the farm we had - she went with it)
Old Jun 29, 2006 | 10:50 AM
John7894's Avatar
John7894
Exactly what lights do you have? The 06 Super Duty's here, if it's a base model XL, still use the old single sealed beam glass lamp. This is on the work trucks with the gray bumper/grill. Is this what you have?
My 01 Lariat has the passenger light burned out and honestly I can't tell. That's how bright the other one is. My 01 lights are the old style diamond cut lenses, not the clear ones like the 02/03's.
Old Jul 1, 2006 | 12:00 AM
Aussie SuperDuty
They look similar to your 03 lights, but are not a sealed beam, and run an H4 globe.
I will shoot out now and get some pics for you all.
