Injector knock
Old Jun 23, 2006 | 11:14 PM
cangim's Avatar
cangim
I'm betting on a bad injector in this case as well. I know several have replace all 8 of there injectors and noticed huge improvements with power and economy, as well as a large reduction in noise. You could probably talk to the vendor and let them know your situation. That way you have some time to swap injectors around if indeed it isn't #3. But if you haven't done the intank mods and pre pump mods yet, I would suggest doing them anyway, as it is pretty substantial the amount of noise reduction. I could actually tell a reduction with out having to listen for it.
Old Jun 23, 2006 | 11:50 PM
Orezona's Avatar
Orezona
Originally Posted by lifted_01_SD
Ok but it seriously sounds like hitting a hammer on the side of the block. It only happens at idle and if its a compression issue why does it run so good above idle. I dont think its the fuel system cause this is the first sign of this white smoke after 200 and some thousand miles. Heck mabey my motor really is shot, but i prefered it wasnt, lol. Thanks for responding to my post Kris and have fun on your road trip. I was planning on driving down from Alaska to Nebraska this july but it looks like im flyin now. later Chase
It will sound like that. Try this, get rid of the one quick-connect at the suction side of the oem fuel pump, go top off with fuel, drive around, stop, get out and put you ear to the passenger wheel well. If the "knock" is gone, it's cackle. Then, and it's a big then, start researching fuel system mods. Your head will be spinning. But that's ok, cause you can ask everyone on here what you're confused about and you'll get the answers you need. Oh ya, get out of the stealership 1st. It may be a bad injector, but try what is suggested here, and I'd bet a cold one you save some money, maybe even do a repair and feel a lot better than you would being jacked by the Stealer.
Old Jun 24, 2006 | 12:07 AM
hink10's Avatar
hink10
Here's where I bought a replacement. http://www.xtremediesel.com/index.as...ROD&ProdID=206 . They say to call for best price, I bought one just a while back, $190 + $150 core. They are brand new OEM Alliant injectors. Good luck!
Old Jun 24, 2006 | 08:46 AM
blown99's Avatar
blown99
Originally Posted by strokin_it7.3
blown99, dont confuse fuel cackle (air in fuel) with fuel knock (overly fueled engine on the verge of hydrolocking). i saw a cummins engine in a superduty at spring fling have fuel knock when they got on the throttle before boost came up. tons of white and grey smoke. sounded bad too. i dont think you are overfueling.-. do you have the ability to replace the injector? im not questioning your ability, but i can show you some sponsors that sell individual OEM injectors if you want to DIY.
Fuel knock is not an overly fueled engine on the verge of hydro locking. Fuel knock is when non atomized fuel is burned/explodes, due to poor atomization (problem in the fuel system, bad injector tip, poor fuel quality, or lack of air for complete combustion. You can totally break a tip off an injector and the engine will run and rev up. You will be pooring fuel out the exhaust and smoking up a storm and a half. Overfueling will give you black smoke. Look at an old mack pulling a load. Cackle is inherent with navistars design of the fuel system and should not be confused with fuel knock (stated this in my other post).
If ford diagnosed #3 then buy an injector and replace #3. You can check there diagnosis with a heat crayon. Mark the manifold and see wich cylinder takes the longest to melt and or melts extremly fast. A raytek gun works the best for these situations though.
Old Jun 24, 2006 | 09:03 AM
clux's Avatar
clux
I agree, I'd replace #3 and see where that gets you. I'd advise you to get it doon sooner rather than later as well. If the #3 injector is that bad, it could wash you #3 rings out pretty fast, and then you will need an overhaul.
Old Jun 24, 2006 | 01:02 PM
lifted_01_SD's Avatar
lifted_01_SD
I hear ya and i hope that hasnt happend allready. I also have more black smoke now, even noticable with the edge products. But thanks agin for all whos helping me i will post with results. later Chase
Old Jun 25, 2006 | 12:29 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Hang in there Chase, somebody here recently had your exact symptoms. It may have been Cangim, and maybe not but I believe he changed an injector and a few other items on his quest. Maybe they will chime in soon. I do specifically remember the hammering symtom though. Hopefully they will be along soon.
Edit: Duh, read the whole post. I think it was Hink. Talk to him.
Old Jun 25, 2006 | 07:11 AM
lifted_01_SD
hey thanks again for all who is helping me. I just ordered a new injector for my number 3 cylinder, I will post with the results, hope it fixes the prob. Chase
xaviar
Jan 28, 2020 12:45 PM
alloro
Mar 10, 2017 02:51 AM
puffen:D
30
Sep 20, 2014 01:16 PM
RedDevil460
53
Mar 29, 2014 08:16 PM
Rigormortise
60
Apr 30, 2013 06:30 AM
