there is preset value of readings in your edge, those numbers are set for normal operations, exceeding that will give you a warning if you turn it on.....and of course you can call edge and ask them where they based their numbers
I did notice the preset values that are listed when displaying the two funtion bar graph. When I displayed the TFT on that graph it shows the high end limit as 230`F.
There has to be a so called "green arc" or normal range area/temp., a caution range, and a redline limit. The 230`F being the redline for the TFT.
It would be nice to know the actual "normal operating limits" for the TFT and the other temp funtions the Edge monitors.
