I have a 1995 ford f350 4 door duelly 7.3 power stroke turbo diesel. I have installed the chip and also a new jasper transmission. The problem I am having is when I shut the hood the truck shuts off. If I go over a bump in the road the truck shuts off. Can anyone give me any idea's on what might be causing this. Thanks.
Sounds like loose wiring. Since it is diesel I am not sure how to stop it but would assume that if the fuel pump were electric or the injectors computer controlled, then those wires would be suspect.
If there is s "accident" switch in the truck it may be getting triggerd by the vibration. I think the accident cutoff is usually behind the passenger footwell panel, but I could be wrong.
Since you messed with the computer, maybe you did not plug things in all the way or maybe you have a loose pin in the connector.
