vacuum tuning/carb mixture
(can you tell i did a lot of work on the truck over the weekend?)
i vacuum-tuned my timing and carb mixture for maximum vacuum pressure. it holds at about 22, with a steady needle. (and man oh man, does it ever run better!)
my question- if the engine is cold, and i use the manual choke to get it started- i can pull out on the highway, and let it idle along in first gear...(with the choke still on). when i drop the hammer, without touching the clutch- the 360 will leave a long streak of hot rubber.
however, if i try it when the engine warms up, without the choke on, all i get is a quick chirp from the tires. does this mean i'm running too lean a mixture?
thanks,
sam
You might want to get a kit that has different jets and different acc pumps and if it's a vac sec try different springs to get the secondaries to kick in at different speeds. When the engine is cold, the air/fuel mix is colder and the exhaust crossover hasn't heated up the intake yet, that alone can make a noticeable difference. You might consider cooling down the intake and carb with exhaust crossover blockoffs and plastic 1" spacer under the carb and maybe a carb bowl heat plate that goes under the carb and float bowl to keep the fuel cooler. I've read where a cooler intake charge can increase power by 7~10%
Another idea is to use an O2 sensor in the exhaust to read the O2 at different times, for example you might be lean at one time and rich at another and an O2 sensor really helps to read the exhaust, cost is about $25 + install and you can use a simple digital multimeter to read the output.
it's the stock ford 2-barrel...i don't know much about jetting, but i'll try to do a little research. i rebuilt the carb a couple of years back, (with an autozone kit) but that's all i've ever done to it, other than toying with the mixture screws.
here's the link for the vacuum tuning-
http://www.public.iastate.edu/~wish/Tech/Tuneup/tune.html
