1997 Explorer XLT
Old Jun 20, 2006 | 08:37 PM
dclybrk's Avatar
dclybrk
1997 Explorer XLT
Does anyone have suggestions on where I can get an owner's manuel for this vehicle? I bought this explorer recently and have no idea how to operate the radio/cassette/cd player. I really would like to set the clock, lol.
2nd question, is there a way to turn on the diagnostic computer to see if there are any error or trouble codes? I know on some vehicles you can turn the key on and off a certain amount of times and the codes will flash on the dashboard.
Any help or suggestions would be greatly appreciated.
Thanks,
dclybrk
Old Jun 21, 2006 | 05:23 AM
marragtop's Avatar
marragtop
Go here for manual: https://www.fleet.ford.com/maintenan...ls/default.asp
You need a OBDII reader to get the codes. Most Autozones will pull them for free. Call ahead to make sure.
Old Jun 21, 2006 | 07:57 AM
dclybrk's Avatar
dclybrk
Thanks for your help, I appreciate it.
dclybrk
Old Jun 24, 2006 | 08:02 PM
vicv's Avatar
vicv
You may have already found this out re the clock set, hold the "clock" button and press either the "tune" or "scan" button to advance hours/minutes. I have a 97 but w/o the CD player.
Old Jun 24, 2006 | 08:09 PM
dclybrk's Avatar
dclybrk
Thanks!
No, have not gotten that little tid bit of information. Thanks for sharing with me. Now I can go and set my clock .
dclybrk
Old Jun 24, 2006 | 08:54 PM
scucci's Avatar
scucci
This is a good place to sign up on for your expy.
http://myford.fordvehicles.com/servl...age%2FHomePage
It is Fords owner page. If you sign up it will check for recalls that are needed and give you the owners manual, radio manual, ect. No cost to sign up. Has maintenance charts and other good info. You can use your Ford username/password to log in to the Motorcraft web site for more usefull info.
Hope this helps
Scucci
Old Jun 24, 2006 | 09:36 PM
dclybrk's Avatar
dclybrk
Thanks!
I will do certainly sign up for this, thanks for the info.
Thanks so much
dclybrk
