1997 Tank Size
Old Jun 20, 2006 | 09:21 AM
Dirty_Pile's Avatar
Dirty_Pile
1997 Tank Size
1997 F350 PSD Crew Cab, Long Bed. Can someone tell me how many gallons the front tank holds? I need to drop the tank to fix my sending unit and I would prefer it not be full of diesel. I could buy a pump and pump it out but i thought I could just run it down, with no guage it makes me nervous.
By the way, I have heard horror stories of people running diesels out of fuel. What happens? How do you get it going again?
Old Jun 20, 2006 | 10:11 AM
willbd's Avatar
willbd
Front tank about 19 gallons.
I have not ran out of fuel in my PS. On other diesel you will need to prive the fuel system. Some have a hand pump on the fuel system for priming after changeing the fuel filter. On my truck I do not prime or fill the filter housing with fuel after changing the fuel filter and the truck starts right up with out and issues.
Old Jun 20, 2006 | 12:15 PM
dedhed's Avatar
dedhed
Dont run it out of fuel !!!
When you change the fuel filter & drain the canister it sits in, you are not losing the prime on the injectors.
Besides, do you really want to suck all the s**t out of the bottom of your tank and run it through your engine ???
Do yourself a favor, pump it out.
P.S. I belive owners manual says 20Gal. front, 18Gal. rear....no other options.
Old Jun 20, 2006 | 01:38 PM
Dirty_Pile's Avatar
Dirty_Pile
I'm not going to run it out of fuel.
I just want to run it down to a couple of gallons so it is more managable than full.
Old Jun 20, 2006 | 03:13 PM
94_turbo's Avatar
94_turbo
pickup is on bottom of tank--suck the tank dry if it wants to--also--you may be able to just loosen the brackets to almost off--and get enough tip out of the tank to get the sending unit out--did that to quite a few tanks when was at dealer--sometimes you cant though--blow the area really clean so get no junk in tank--
Old Jun 20, 2006 | 03:39 PM
Dirty_Pile's Avatar
Dirty_Pile
thanks 94_turbo, good info on the tipping the tank thing.
I figure 290 miles ought to be good to get it down near empty. Do you guys agree? (btw, truck is bone stock 5-speed 4:10 gears 4wd)
Old Jun 20, 2006 | 11:16 PM
BigRed350's Avatar
BigRed350
I have the same truck, '97, Crew w/ Long Bed. When I first got it and didn't know any better, I ran each tank out completely, and then topped them off to see exactly what they held. I got exactly 21 gallons in the front and 19.5 in the rear. I have heard other results on this forum though, maybe there are some differences I don't know about. When I was filling them, I took my time and let the foam subside and then put in a little more until the fuel was right at the top of the neck.
BTW, when I ran the tanks dry, I noticed a sudden loss of power and the RPM's took a nosedive, like the engine went to about 400 RPM. I flipped the tank switch and after coasting for about 20 seconds the engine kicked back in and I was on my way. I was on the highway going about 70 when this happened (both times).
Old Jun 21, 2006 | 06:34 PM
plowhand's Avatar
plowhand
Playing in the Dirt
It is not a good idea to run your tanks empty before switching. The injectors are fired by the high pressure oil system. The fuel that is being injected is used to cushion the injector piston. Below was taken from the dieselmans page:
"Since the cavity at the top of the intensifier piston is seven times the size of the fuel cavity at the bottom, fuel is injected at a pressure seven times that of the computer-controlled oil pressure--oil pressure 3000 psi = injected fuel pressure 21000 psi. "
Just FYI.
Old Jun 21, 2006 | 07:03 PM
bodabdan's Avatar
bodabdan
Veteran: Navy
I respectfully disagree-
The pickup always pulls fuel out of the bottom of the tank. If there is something solid in there that is heavier than the fuel, it's always near the pickup of the fuel tank. Picture putting a drinking straw in a glass and putting the straw as far down as you can. If you drop a heavy object in your drink it will go to the bottom where the straw is.
On the other hand if you have some crud floating in the tank that is lighter than fuel, you could give the light stuff a chance to get sucked into the fuel system if you run the tank dry.
I do agree with plowhand on this one. Almost any type of pump can be damaged if run dry, and an injector is just like a pump in many ways. Once or twice probably wouldn't hurt anything but I would not run dry on a regular basis.
BTW my 97 has dual tanks and when the gauge reads empty it take about 14 in one and 16 in the other. I have never ran mine dry so I don't know for sure how much they will take if dry.
Old Jun 23, 2006 | 01:47 PM
Leader's Avatar
Leader
I HAVE run mine dry ... just to see how muck they hold. I can get over 20 Gals in both of them. If you are going to pull the tank off the truck, I would run it DRY then switch tanks... Our trucks are self primeing so it will fire up again without you doing anything special. If you are stopped when it runs out, you just crank on the starter till it fires... It will run a little rough till the air gets pumped out of the system but it will be fine.
