1978 - 1996 Big Bronco
Retrofitting a tilt wheel
Old Jun 18, 2006 | 09:39 PM
biederboat's Avatar
biederboat
I did a bit of research on this but couldn't find exactly what I was looking for. Got a 92 Bronco w/ no tilt & aftermarket cruise on a side "stick" past the turn signal lever. I want to install a tilt wheel and also buy an aftermarket steering wheel. Will aftermarket wheels work in a tilt wheel that was probably designed for integral cruise? I'm not wanting to integrate the aftermarket cruise, it's fine where it is. Also, does it matter if I buy a tilt wheel system designed for air bags or not? Mine didn't have them. Lastly, do I need to get one out of a Bronco? I'm presuming I can go F series but are there any Ford cars that have a compatible column?
Thanks,
Biederboat
