Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
ABS Speed Sensor
Old Jun 18, 2006 | 12:29 PM
totallyconfused's Avatar
totallyconfused
Question ABS Speed Sensor
I am having difficulty finding an ABS speed sensor to replace on my 2002 Escape, does anyone have any idea how complicated it will be to replace it?!
I also need to clean my EGR Valve port, where is it?
Old Jul 9, 2006 | 07:25 PM
bluestang65's Avatar
bluestang65
What motor do you have? EGR is pretty easy to find. On the 3.0L it is right on the drivers' side of the intake. Which speed sensor is bad?
Old Jul 9, 2006 | 07:49 PM
totallyconfused
Smile found it
Thanks blue, I already found the EGR, not sure that was my problem. I think it is the DPFE! I cleaned the EGR valve port and I am getting better milage, but the OBD light is still on.
I got the ABS speed sensor changed out. That light did go out! Yippee....
Thanks for the response. I guess I am not as confused as I thought.
Old Jul 10, 2006 | 09:39 AM
bluestang65
What is the OBD II code you are getting?
