Hey Yet Another Gear Ratio Question
Old Aug 23, 2001 | 07:16 PM
Crazy_John69's Avatar
Crazy_John69
Ok i know every one has gotten tired of gear raion questions so ill give you guys/gals two in one. ok my truck is a 1976 ford f-250 with 38 inch super swampers on it and i want to put 44's on it but i'm clue less about gear ratio.
what size gears should i put in it if i use 44 inch tires?
Also my friend has 50 inch tires what gears wloud you put in then i might just put them 50s on insted of the 44s but still would like to know the ratio for both tires
i would like the truck to have speed on take off and speed of 65 at regular rpms basicly i want the truck to be fast and i don't care about gas. also it has a 4 speed with creeper gear thanks for all that reply
Old Aug 23, 2001 | 07:58 PM
Flash's Avatar
Flash
I think the first question you need to ask yourself is "how the heck am I going to stop this thing".As tire size goes up- brake capacity falls-FAST. I've seen too many big tired trucks on top of cars cause they couldn't stop.
Old Aug 23, 2001 | 10:42 PM
gtex's Avatar
gtex
Check out :
http://www.4lo.com/
They have several calculators that will tell you the effective gear ratio after upsizing your tires. I didn't think you could get 50" tires without going to some custom military axle conversion. Good Luck!!
Old Aug 24, 2001 | 01:19 PM
PetesPonies's Avatar
PetesPonies
Old Sep 4, 2001 | 10:10 PM
7855F100's Avatar
7855F100
http://www.bgsoflex.com/speedo1.html
http://www.gearedbyunitrax.com/main.html
wildcard221
Feb 15, 2017 06:23 PM
Rusty_S
Sep 30, 2016 10:17 PM
'77fordtony
19
Dec 5, 2015 12:51 PM
79 Trailer Special
Feb 20, 2004 07:46 PM
tunainmesaaz
Sep 19, 2003 08:55 AM
