Sponsored by: Auxito
That F..... Wire Again!
Old Jun 17, 2006 | 12:40 PM
benton's Avatar
benton
I have a '99' with the 4.6. My father has a '97' with the V6. Both of us have had the main battery lead (batt. to starter) rot out at the starter TWICE. That's four times between us! Guess what I'm doing today....fixing number 5! Has anyone had similar problems? Anyone know if there's a recall on it?
Old Jun 17, 2006 | 05:46 PM
NorminN.B.'s Avatar
NorminN.B.
Thumbs up
My father in law has a 94 f150, that had the same problem. The truck is in perfect condition, with only about 70 k, on it. The cable even looked like new, but was bad. A new one solved the problem. NorminN.B.
Old Jun 17, 2006 | 07:06 PM
Bdox's Avatar
Bdox
What is it caused by? Corrosion, flexing or heat?
Old Jun 17, 2006 | 07:52 PM
benton's Avatar
benton
might be corrosion or heat. I'm guessing corrosion. Tried to find a new wire today. Looks like I'll have to wait for the delearship to open on Monday.
Old Jun 17, 2006 | 09:03 PM
Bdox's Avatar
Bdox
Maybe you should get an aftermarket cable with a few inches extra length. Coat the end that fails with silicone grease. The extra length will allow you to route it away from the heat sources. Maybe upgrade to the next larger diameter while you are at it.
Old Jun 17, 2006 | 11:47 PM
benton's Avatar
benton
I agree wholeheartedly dbox. Problem is can't really find anything that works. it's got two wires and a fusible link. If you know any where to get an upgrade it would be appreciated.
Old Jun 18, 2006 | 12:16 AM
Bdox's Avatar
Bdox
Sounds like an expensive Ford part to be changing so often. If it were me I would just get an upgrade cable then add the two wires and the fusable link on to the battery + with a ring connector.
