Code 33 and 67
Old Jun 16, 2006 | 11:14 PM
apropos's Avatar
apropos
Code 33 and 67
'90 F250
I pulled codes and got: 33 - EGR valve not opening, where do I start?
I also got 67, which is neutral drive switch is that also known as "neutral safety switch" located on the tranny?
Old Jun 17, 2006 | 08:58 PM
fordf150guy's Avatar
fordf150guy
its egr not closing fully (for trucks) and i think on cars its egr not operating properly. take off your egr and try to clean all the carbon junk out of the valve seat area. re-install, clear codes, and take your truck for a quick burn with some wot passes (try to blow all the carbon threw). then check your codes again.
Old Jun 18, 2006 | 12:30 AM
apropos's Avatar
apropos
I looked carefully at the "H" manual (all the codes/sensor stuff) and it basically said it could be several things, the EGR valve sensor, the EVP sensor and what you described. It also talked about testing with a vacuum tool, which I have no idea how to use.
How often does the valve and the EVP sensor go bad, anyway?
It has 95K miles on it.
