ok help!
Old Jun 16, 2006 | 10:37 PM
orangebanzai's Avatar
orangebanzai
Unhappy ok help!
-ok got 2.3 l 94 ranger
-barely creeps forward then slowly picks up speed
-sounds terrible, like cat is vibrating, on 3rd cat now
-top speed 35-40 nearly floored on gas
-can smell gas and it uses more now
-cat has been glowing red several times,too much fuel in mixture, right?
-ford shop 1st said i needed new plugs and wires and injector cleaning-i changed plugs and wires, nil on improve
-just put on o2 sensor,nil
-second trip to ford (on their nickel) they said i need new PCM...maybe yes/no..wont bad sensor elsewhere just screw it up again??
-Handleman thinks maybe new dis pack needed(ignition control module)..leaning that way, but 200 bucks
-cleaned trottle body intake etc
-changed relays in engine bay fuse box
-got 160, 000 miles, five speed manual
-if timing belt is notched, could be off a few??
-U GOT ME LOL !!!!
any way to lean would be helpful
Old Jun 17, 2006 | 01:24 AM
CowboyBilly9Mile's Avatar
CowboyBilly9Mile
What DTC(s) is it showing? Has anyone checked the fuel pressure regulator, in particular the inside of the vacuum line leading to it for the presence of gas? Is it safe to assume that the air filter is in good condition?
*How did the Ford dealer arrive that the conclusion that a new ECM is needed?
Old Jun 17, 2006 | 12:11 PM
RangerPilot's Avatar
RangerPilot
Indeed, where'd they get that idea?
Have the codes pulled. It'll be a slow drive to your local AutoZone or the like, but get up to a parts store and have the codes pulled, that will lead us in the right direction and you can buy parts that will help as opposed to just random ones.
RP
Zach
Old Jun 19, 2006 | 10:34 PM
orangebanzai
thanks for responding cowboybilly and rangerpilot
went back to ford after work today and got hardcopy of what the tech found on my ranger...
'caused by SELF TEST SYSTEM. retrieved dtc 222 idm low,rh coil. perform pinpoint test b. normal plugs kb from both coils.
install breakout box and harness adaptor. measured voltages.
pinpoint test detects failure in PCM. disconnect and removed all test equipment for diag.'
Cowboy, gonna check fuel pressure regulator like you suggested hopefully tomorrow night....buddy also has gauges to check pressure at fuel pressure test port on fuel rail.
Sure wish 'Overhauling' would show up and rebuilt my vehicles, hahhh!
thanks for the help ..........
Old Jun 20, 2006 | 06:57 AM
sfcwoodret's Avatar
sfcwoodret
Have a full diagnostics test performed at a Ford dealer or certified auto mechanic.Troubleshooting these days can be expensive when you end up replacing things that do not need replacing.
Old Jun 20, 2006 | 11:44 PM
orangebanzai
well checked fuel pressure regulator...had constant pressure in correct range...checked current coil packs, ok...now thinking it is dis pack (ignition control module)...guess that is next step...also read sites where the code 222 was the ignition pack....
Old Jun 28, 2006 | 11:40 PM
orangebanzai
ok handyman, rangerpilot, and cowboybilly
went to oreilly's after work and tested my ignition module...it read bad both low and high rpm....got new borg module, put on and the truck runs like a screaming banshee...yeeeeeeeeee haw !!!!!!!!!!!
